Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Replace liftmaster 1245R drive/worm gear
My liftmaster 1245R does not work anymore. Need to replace drive/worm gear. How can I change it.
thanks,
  • interalejo Dec 15, 2008
    Same issue as the original poster...
I have a 1265 and took the cover off (unplug first).
There are screws securing the cover: 2 on each side at top, 2 at either end bottom.
Then I disconnected the chain.
There are 3 hex head screws securing the drive gear assembly (of course they thread from the inside out which makes taking them out a bit time consuming). Take care not to damage the circuit board or other electronic connections.
Then at the bottom of the shaft is the "limit switch assembly" that is clipped into the metal housing. Squeeze the 2 on the outside and it should swing free.
Then at the very end of the shaft there is another plastic gear. It is secured by a 3 prong plastic clip. Pull the outside clips away from the shaft while pushing the center piece back through the shaft. The gear should come off and you can now remove the gear and sprocket assembly up through the assembly.
call 800 528 2817 and order the "Gear and Sprocket Assembly".
I am waiting for the part and assume we reverse the order above to reinstall.
Posted on Dec 26, 2008
Look at another web re how to replace a stripped gear of a garage door opener. Look at "galtrying" concerns. I have posted a quote on how I did mine with motor out. Easy as a piece of cake.
Posted on Jan 09, 2009
I have a sears 139.53647srt garage door opener. It is 16 years old. The nylon drive gear finally stripped. Is itt worth replacing the gear, or replace the whole unit. I am mechaically inclined, but can...
I think buy a new one in better choice. For its old equipment, maybe you'll hard to find compatible spare part anymore. But its your choice, if you love your door so much, and if you can find the spare part, just change the gear would be okay.
Hope this help.
Jan 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage 13953664SRT worm gear stripped who do I replace it
If you buy the gear kit part number 41A2817 it comes with instructions. It is available at any good door opener service company.
Jan 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
Is there any adjustment for the gear drive sprocket that meshes with the worm drive? my gear is not engaging any more
If your drive gear is not meshing with the worm gear it is because it is worn out. You'll need to replace it post haste. The part number is 41A2817 and is available at Sears or any good door opener service company.
Dec 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need to change plastic 3" diameter gear that is driven by the worm drive gear
The part number for the gear kit is 41A2817. It comes with instructions and is available at any good door opener service company.
Dec 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door motor dead
Keep checking for loose wires. Nothing about changing the gear should cause the motor to stop running. Check the wires on the start capacitor and follow the white wire from the motor and make sure it is connected.
Dec 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster mod 1245R (1999) has indicator light blinks 5 times. Door will not operate from hardwire button. Tried unplugging unit to reset but same 5 blink sequence returned. Held button in to reset but no...
The trolley is most likely jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. Now locate the 'up limit' control on the side of the motor unit. Turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Dec 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens 4 inches then reverses and stops
you need to replace gear when the door is fully closed. then do your tweaking.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need part 41A2817 drive/worm gear kit for Sears
as long as the door is less than ten years old, sears will stock the part you need. you can contact them through this link.
http://www.searspartsdirect.com/partsdirect/index.action?psid=58709328&sid=PSx20071217x00001a
Apr 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
4,687 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
