Just got the Asus Crosshair II Formula motherboard, AMD 9950 BE cpu & 8 gigs of 6400 ram. Slapped the entire setup together made sure that everything was done correctly and tried to power up the system. Inititally the system stayed on about 5 secs, and then just started cycling. Called Asus tech support and the guy I spoke to said that it sounded like a grounding issue. Told me to put electrical tape over the brass studs coming off the case and then retry. Did that and there is no significant change. Please, I need to have this system up and running before tomorrow morning, so any help at all would be greatly appreciated.
Change the ram of *********** Bord u have to need a 400 mhz ram for to solve this problem dont bye first chak it to anther PC ram then if its work then buy a new ram or change the smps of your system
i think its help u
Was the operating system loaded properly............
i will have to tell u to check ur connections again...may be ur ram is not properly
fitted in place
Sir, did you setup the motherboard to the cpu case all by yourself? tell me exactly what you did. thanks!
CHARCOIS
