Tv sanyo dp42740 no prende el led no enciende la tv
I have 5volts stby and 3.2volts but is no power in the switches to turn it on and of
shaggyrat
  • 1224 Answers
SOURCE: Encendido del LC-32GA5U
no abla espanol this is america translate your question first
Posted on May 13, 2008
SOURCE: bunas dias , mi problema
Que tal yo tambien tengo el mismo problema con mi tv insignia de 32¨ , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes estan presentes a la salida de la fuente, cambie todos los filtros de la fuente pero nada, gracias por su ayuda.
mi corre es carlitoswwway@hotmail.com
Posted on Dec 27, 2010
bbl242003
  • 1637 Answers
SOURCE: Buenas noches, tengo una hitachi
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
SOURCE: tengo un plasma sanyo 50
Amigo yo tengo el mismo problema con el mismo plasma..y no encuentro solucion...Tu ya pudiste arreglarala?? Ojala pudieras decirme como lo resolviste o cualquier info al respecto...gracias.
Posted on Feb 23, 2011
ChungYu
  • 76 Answers
SOURCE: EL TV NO PRENDE LA
que?
Posted on Mar 01, 2011
Mi ranger prende i se apaga a fuerza le prende el foco de la pila y la auja de la carga esta abajo no se que es alguien save
Diana si se enciende la luz de la bateria lo mas comun es que necesites remplazar el alternador asumiendo que la correa este en buenas condiciones
Aug 07, 2015 | Cars & Trucks
Tv green light flashes
cuando le dan a prender prende el led verde y la tv prende prende por 3 segundo presenta en la pantalla el letrero sony y se apaga la tv y el led verde. luego prende el led rojo 2 parpapadeo pausa larga 2 parpadeo y pausa larga y se repite
Dec 08, 2013 | Sony BRAVIA KDL-40V3000 Television
Le canvie la lampara y no enciende
esta seguro que la puerta esta cerrado con el tornillo y el lampara es bueno y dirme si despues que tu la prende si tu ves algun luz alfrente del television prende y pagando??perdon por mi espanol yo se un poquito.marca el nombr del tv y model te puedo ayudal:):)
Aug 27, 2013 | Televison & Video
Eee pc 90ha mb pantalla negra no enciende
Tengo un pc eee top et1602 y la pantalla no enciende se queda negra los led si prende el ventilador tambien ando preocupado si alguien tiene repuesta a este problema por favor enviarme un correo digitalpaint2012@gmail.com o por aca
Feb 16, 2012 | ASUS Eee PC 900 PC Notebook
Mi televisor no enciende solo se prende el foco rojo y parpadea en donde dice timer
bueno tengo una television pt4298hd akai el problema no enciende parpadea el foco de timer 10 o 9 veces y no enciende destape la tapa de atras y desconecte un cable rojo que tiene el nombre de screm y la television enciende pero no se mira como debiera porque se mira el color verde y el rojo pero como si le faltara el color azul mi televisor es una dlp akai de tres lentes y quisiera saber cual es el problema
May 02, 2011 | Akai PT4298HD Rear Projection Television
Bunas dias , mi problema es que la tv insignia no enciende a pesar de que la fuente genera todos los voltajes, al dar power el led cambia de rojo a azul pero no hace nada, como dije todos los voltajes...
Nov 30, 2010 | Insignia IS-LCDTV32 32 in. Television
Tengo un plasma sanyo 50 pulgadas modelo dp50747m lo que tiene es que: no prende y le cambie los fusibles que estban quemados pero ahora se oye que prende pero no se ve nada solamente se enciende el...
Sep 05, 2010 | Sanyo DP50747 50 in. Plasma TV
Tengo un lcd de 55 y la luz roja titila y no enciende
Julio, tengo el mismo tv. me lo regalaron con ese problema. Decime cuando apagabas el tv (cuando funcionaba bien) que luces se prendian y que hacian hasta que se apagaba todo. Ahora cuando lo prendes decime bien que luces se prenden y como lo hace. Saludos.
Aug 24, 2010 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
No prende
Fito: Cuando la TV se apague, presiona los botones "Input" y "Menu" al mismo tiempo mas o menos por 8 segundos, el led comenzara a flashear, luego mostrara un codigo de error, cuando tengas el codigo, lo posteas de neuvo para revisarlo.
Jul 05, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Mi pmp carga y enciende su luz pero no quiere encender el aparato
YO TENIA UN PMP ME PASO LO MISMO. Y TEMO DECIRLES QUE MURIO, TUVE QUE CAMBIARLO, LO QUE ME DIJERON FUE QUE SE DAñO LA MEMORIA Y LA BATERIA, ASI QUE PAILA. TAL VEZ EL TUYO NO SUFRA LO MISMO
Dec 06, 2008 | iRiver PMP-140 Digital Media Player
Televison & Video Logo
168 people viewed this question
Top Televison & Video Experts
Electro Med Services...
