Question about Dyson DC25 Animal Bagless Upright Vacuum
Belt isn't turning the brush head
The brush head is turning manually freely but the belt doesn't seem to be turning it when swiched on. The belt appears to be still attached
  • Official Brand Answer
  • 2,572 Answers
I'm sorry to hear you're having difficulties with your DC25. This model is equipped with a belt designed to last the lifetime of the machine, and we'd advise against attempting to access this, as this can void our 5-year guarantee.
If the brushbar isn't rotating, it's likely that the machine just needs resetting. This is easy to do - please follow the steps shown in the video below. Our online support guide may also be useful:
http://www.dyson.com/support/help.asp?article=1156&product=DC25-ANIMAL
This should resolve the issue, but if you'd like any further assistance or advice, please get in touch with us directly by calling our Helpline free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
[unremark-end]-->
Posted on Feb 23, 2012
SOURCE: DC 07 BRUSH BAR DOES NOT TURN BELT OK
the belt canot be replaced on the 07 you have to replace the clutch witch is the brush control
Posted on Jun 17, 2007
Agent Don
  • 310 Answers
SOURCE: brushes not going round
The brushes on my dyson have stopped going round. I have checked it and they move freely by hand. The belt is intact. What could the problem be? The Hoover is about 10 to 12 years old.
My dyson is a dc04
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
One of the main problems with vacuums are that the flat belts on the vacuums stretch and should be changed every 4 to 6 months or 3 or 4 times a year – you can tell by taking off the belt or belts on the vacuums and compare them to the old belts on the vacuum the new belts will fix inside of the old belts and you will be able to see the difference on how much they have stretched – if the belt is a geared belt – they stretch as well but should be changed about one a year – the cost is not that expensive and you cleaning will improve almost double – this also applies for the Dyson DC04 and the Hoover vacuum as well – some of the Hoover vacuums have two (2) belts and they both should be changed @ the same time.
Posted on Apr 15, 2008
SOURCE: Dyson 17 Brush Belt Broken
there is also an updated beater bar that accepts a wider belt, dyson sent it to us for free
Posted on Jul 03, 2008
  • 43 Answers
SOURCE: no suction in floor attachment *& brush not turning
Lay the machine on the floor with the front side down. Undo the 3 large plastic screws with a coin of some sort, then remove bottom panel. On the back of carrage where the roller bar sits their should be a clear plastic tube check this tube is free of dirt. Check around inside the carrage for hair string etc. Check belt for breaks and swelling in the rubber pull ont roller bar and check the end caps on the roller can spin freely. If not pull off the end caps these will be very tight and wash out all dirt and fluff, dry thourley and lubricate centre pin and end caps inside the roller with baby oil or wd-40. replace roller bar and belt, turn roller bar twice slowly to centralise the belt, replace bottom panel making sure that the clips on front are sitting in their holes. fastern the plastic screws and leave two hours before usage
Posted on Nov 11, 2008
  • 83 Answers
SOURCE: beater brush won't spin but belt is intact and ok.
For your beater brush to spin, you have to meet two conditions:
1) the vacuum cleaner has to be reclined (put your foot on the front and pull back on the handle).
2) The clutch actuator (the dial where you switch between BEAR FLOORS and CARPETS needs to be set to CARPETS).
If the brushbar/beater bar still doesn't spin after that, call the Dyson helpline, they will assist you. If you are saying that the brushbar isn't spinning because it is not picking up any dirt, you may have a loose internal hose, a blockage in the machine or the bristles on the brushbar are worn. Call the Dyson helpline for assistance.
Posted on Jul 30, 2009
Belt no longer turns the brush
JKGonzo:
You'll need to open the vacuum head and remove the beater bar. Clean up the bearings at each end of the beater bar and reassemble the head.
May 25, 2013 | Rainbow Vacuums
Bissel 3760-4 brush motor doesn't turn on
Hi Tim. I understand the brush is turning & belt is fine. You may want to remove and reseat the canister. If this doesn't work, you'll want to have one of our Authorized Service Centers inspect your vacuum.
Here's a link to assist you in locating one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Apr 19, 2013 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell bagless 6583 brush won't turn after new belt
Sorry to hear about the difficulty with the brush. If your brush does not turn by hand freely, then your brush needs to be replaced.
Here is a quick link to order a new brush:
http://www.bissell.com/parts/?id=9143&sc=part&partid=17048&cid=ccsocial
Mar 20, 2013 | Vacuums
The brush bar isn't going round ?
your problem seems to be the belt has snapped. Underneath the the hover there is a rubber belt that connects around the brush bar and around the motor, this belt will be broken. They can purchased from any hoover shop for a couple of pounds.
Jan 06, 2013 | Dyson DC24 Ball All-Floors Upright Vacuum...
Bottom agitator brush bar doesn't rotate.
First, check to make sure the brush bar is on. The switch is right next to the machine's on-off button, and it is easy to accidentally turn it off when you turn the DC 25 on or off.
Next, check for and clear any obstructions in the brush bar housing.
Finally, check for belt wear and replace if necessary. There is a very video online showing the procedure.
Jul 21, 2012 | Dyson DC25 All Floors Bagless Upright...
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 | Vacuums
Bissell proheat 25a3
Your belt is worn out now because it has heated up and stretched. Take the belt off, You can get to it by removing the cover underneath near the brush. You may have to pull out the round brush bar that is holding in by friction and gravity towards you while the vacuum is upside down, but first, Manually turn the brush and see if it turns freely while still in the holder. If it is hard to turn, take some type of lubricant, something that doesnt attract dust and grease the bearings. That may work fr awhile. If it doesn't you will have to replace the brush.
Apr 22, 2012 | Bissell Vacuums
The brushes won't turn, and cleaning the filter (as suggested in the owner's manual) doesn't help.
Hi ken wright.
Remove the bottom of the head of the vacuum...remove the roller brush assembly.
Clean the assembly...remove the end caps and clear all hair,strings,etc from the end cap and rotating brush head.
After cleaning the brush head and bearings, lube the bearings with a good grade of machine oil such as 3 in 1 oil.
Check your belt condition.
Reassemble and you should be good to go
Please take time to rate me
Sep 05, 2011 | Vacuums
My brush will not turn, and the brush control is stuck on "off"
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Jul 05, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Dyson DC25 Animal Bagless Upright Vacuum Logo
43 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
