Nov 28, 2007
-   First, am new here. Second, have visited many many other washer repair forums in search of a quick solution---none so far.
A top loading Amana washer, between 5-10 years old, Model LW8203W2 PL 8203W2B.
I found the timer shaft totally frozen and damaged and the belt burned out.
The lid switch was bypassed. I replaced the timer and belt acquired from Reliable Part, etc. For two weeks now, the unit will not spin in any of the three modes of wash. I manually checked all the wiring harness, motor windings included--they are ok per diagram from an online Amana Manual.
But I noted the motor switch housing lost the lower footing for the white plastic switch. I replaced the whole housing. I also checked the new timer and noticed that the number of pins were not the same as the original timer so I switched internal contents.
I tested the pressure switch and it seems to be ok.
I totally dismantled it and checked the tub and agitator turn properly and easily.
After all the above, the washer will fill, the motor gets acitivated to agitate only and that is it, the timer does not advance at all and so NO SPIN OR DRAIN, NOT EVEN A HUM to indicate it is going into spin mode. Sometimes, if I interrupt the pressure switch a loud hum but that is it, no spin/drain.I suspect the motor may also be bad but the windings test indicate OK.
My focus now is some wires that I am not comfortable with their positions. Problem that I face is that the previous tech did not leave the wiring diagram/schematics so am having fits to get them in their proper places.These wires are: gray/black to terminal 1 of pressure switch; brown black to terminal 2 and two pink/blue wires to terminal 3. The next three wires go to the temperature switch: blue to terminal L, orange to terminal 4 and black to terminal 3.
So what am I missing or not doing right? If I get this fixed before Christmas, my ulcers with go back to zero. Help.
Luhk
