Question about NetGear WGR614 Wireless Router
Netgear bits i need help because i just setup my netgear wireless and now its not working because it says that i need less bits
  • driller235 Oct 23, 2008
    its messed up i get a new netgear wnr2000 and i put the wrong bits in and now it wont let me get on it on my windows computer
  • john george
    john george May 11, 2010
    could be more specific about the network configuration that you have AND THE MODEL OF NETGEAR ROUTER THAT YOU HAVE
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Sep 06, 2009
Netgear's set up cd does not run on a 64 bit vista... you have to set it up manually through the router page...
connect first your modem to the internet port of your router, the internet port is usually yellow and is isolated from 4 lan ports. then connect your computer to any one of the lan ports of your router as well. power up your router. then open an internet browser and go to this address, "routerlogin.com" if this doesnt work try 192.168.1.1 or 10.0.0.1, it will ask for a username and password which is "admin" for username "password" for password. once you get in the router page click on basic settings on the left side, on the first question "does your internet connection need a login?" select no.. scroll down on router MAC address select use computer mac address and then apply... you should have internet now.. on the left hand side just below basic settings is wireless settings... there you can set your wireless network
Posted on Aug 30, 2009
Not able to connect the extender to my apple time capsule? no wps button. can i use this extender?
Hi, yes you will be able to use the Netgear range extender with the Apple Time Capsule, provided you configure the Time Capsule's wireless settings based from the wireless security you have setup on the Netgear router or extender. No need for WPS button. Just treat the time capsule just like another wireless laptop.
For instructions in setting up wireless settings of Time Capsule click on this link -->> http://www.apple.com/timecapsule/wireless.html
Hope this helps. Glad to be of service.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
Hello my computer is recognizing the router netgear 3400 , the connection is working without the router but it's not going through it .
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Feb 17, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I have two routers Netgear DG834Gv3 and Thomson SpeedTouch TG585v7. I want to create a wireless bridge between these two routers, so that I can have internet on the Netgear router. The main router/Access...
I am sorry but I am not so familiar with the Thomson Device but I can give you a clue on how to set it up....you can skip the security settings first just make sure they work then you can set it later...Check it out!
- Thomson as "Master Router" connected to modem set up as follows
-- 192.168.1.1
-- Set up wireless access point as you normally would in Wireless Settings, muine are "MY_SSID",Channel 2,b+g mode,
64-bit WEP with hex key (rather than pass phrase)
--- Enter any laptop wifi MAC addresses in the "Client Access List" here to allow them and make sure it's set to restrict
them
-- Set DHCP range to 192.168.1.10 to 192.168.1.127 (my preference) in "Lan Settings"
-- go to Wireless Bridging and Repeating menu option
--- Set "Enable Wireless Repeating Function"
--- Set as "Wireless Base Station"
--- DO NOT check the "Disable Wireless Client Association" if you want to be able to use laptop wifi
--- Enter the mac address of your "Slave Router" here
Make sure all of the above is applied and has stuck, i had a habit of setting some things then clicking to a sub-menu
before clicking apply, always scroll down and click apply before drilling into sub options!
DG834G V3 : "Slave Router"
-- Get latest firmware as earlier v3 firmware doesnt support WDS
-- 192.168.1.2
-- Enable Wireless Settings and set to exact same as "Master Router" including 64 bit WEP key and MAC access list for
laptops etc
-- Disable DHCP in Basic Setup (I think)
-- "Advanced Wireless Settings" menu option
--- "Enable Bridging and Repeating"
--- Select the "Wireless Bridge With Client Association" (or similar) option
--- Enter the "Master Router" MAC address here
Again, double check everything has stuck, that the "normal" wireless settings for both routers are identical and reboot
both (in either order worked for me but booting the Master first is probably best practise)
GOOD LUCK!!!
I
Oct 26, 2009 | NetGear DG834G Router
Can't get the setup disk to setup. Says
No you just need a Vista 64bit driver. Try this download:
http://kb.netgear.com/app/answers/detail/a_id/784
Oct 04, 2009 | NetGear WGR614 Wireless Router
Sierra Wireless AirCard 595U And PS3
I understand that you want to connect the PS3 using the Wireless card and NETGEAR card. Please note that the setup you have will not work for internet access. You can not configure the Air card to work with NETGEAR router. you need to have wih a broadband connection available for this router to connect to internet.
Once you have the router configured with Internet access then you may either connect the PS3 wired or wireless to the router, like you connect a desktop or laptop to the router.
Jan 12, 2009 | NetGear WGR614 Wireless Router
Secured networking
Configuring WEP:
1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
3. Click Wireless Settings under Setup menu.
NETGEAR Router WEP
4. Under Security Options, Select WEP (Wired Equivalent Privacy)
5. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
Hope that helps.....
Jul 06, 2008 | NetGear WGR614 Wireless Router
Netgear wireless router
on your computer, open any browser, type 192.168.1.1 or 192.18.0.1
on the login window, type admin for the username & password for the password. (assuming you haven't set the router to have a custom username/ password.)
click wireless settings under setup menu. under security options, select WEP, choose authentication type as automatic, encryption strength is 64-bit (or 128-bit)
select key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) click apply. Please note down these values - You must later configure your wireless computers with the same setting.
you can also select WPA-PSK, as the passphrase, just choose that option on the security options, type in a word or group of printable characters in the passphrase box. it must be 8-63 characters in length, hit apply.
Apr 13, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Just want your opinion
Standards
  • IEEE 802.11b, IEEE 802.11g, 2.4 GHz
Physical Specifications
  • Dimensions: 8.8 x 6 x 1.2 in (223 x 153 x 31 mm)
  • Weight: 1.2 lbs (.5 kg)
Performance Advantages
  • When used with RangeMax client adapters, delivers the longest range of any wireless technology on the market up to 500,000 square feet of uninterrupted coverage*
  • Maintains video quality up to 10 times the effective speed when at long distances
  • Improves performance of existing legacy 802.11b and 802.11g wireless devices up to 50%
  • Five 10/100 (1 internet, and 4 LAN) ports equipped with auto-sensing technology
  • Data speed of up to 108 Mbps*
Privacy & Parental Control
  • “Trusted user” controls
  • Time-based usage controls
  • Web site logging
  • Remote management
  • URL content filtering
Security
  • Double Firewall
  • Network Address Translation (NAT) to hide PCs & files from outside users
  • Stateful Packet Inspection (SPI) firewall to deny outside requests for personal information
  • Denial of Service (DoS) attack prevention
  • Intrusion Detection and Prevention (IDS)
  • Wired Equivalent Privacy (WEP) 64-bit,128-bit encryption
  • Wi-Fi Protected Access (WPA, Pre-Shared Key)
  • Wireless Access Control (SSID) to identify authorized wireless network devices
  • Supports 2 VPN pass-through tunnels (IPSec, L2TP, PPTP)
  • Exposed Host (DMZ)
  • MAC address authentication
Warranty
  • NETGEAR 1-year warranty
Package Contents
  • RangeMax Wireless Router (WPN824v2)
  • 12V, 1.0A Power Adapter, localized to country of sale
  • Ethernet Cable
  • Vertical Stand
  • Setup Guide, Setup CD Warranty/Support Information Card
this product seems good, but do you need only wifi o do you want also wimax?
Sergio
Mar 05, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear WGR614 Wireless Router Logo
74 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
