Question about Honeywell Heating & Cooling
LENNOX MODEL:G26Q3-75-1 S/N 5894L37210 Furnace will start and run for a few minutes and then the gas valve turns off. The burner will cycle on and off without staying on to complete a full heating cy
The thermostat, flame sensor, pressure switch, high temp switch, and inducer blower (blower runs and drains properly) have all been checked and are in working order. The problem got progressively worse and now the furnace will not light. The gas valve was clicking and buzzes at times while it was cycling. But as the problem got progressively worse the gas valve will not even turn on the pilot light when the igniter starts. There is a very faint smell of gas but nothing overpowering. Had the furnace for around 20 year and never smelt gas at the furnace before. I suspect the gas valve is faulty. Any ideas? m experts
4 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: Yokr gas furnace will not start up
You could have the gas co to check to preassures at or before the unit. Too low or high a preassure and the gas valve cant regulate the proper flow>>Natural gas to the house needs at least 5"-wc psi ---to the gas valve needs 7.5"--wc and while its calling for heat the orrifice needs 3.5" -wc psi! Propane needs 11" wc psi to the valve on the unit and 11' -wc psi to the inside furnace.
Posted on Dec 21, 2009
  • 1033 Answers
SOURCE: I have a lennox G26Q3-75-2 furnace it ignites you
Hello, most likely the capacitor has failed and needs to be replaced. the capacitor is a small oval or round can with either two or three prongs on it. When a capacitor goes bad the motor has trouble starting.
Posted on Feb 23, 2011
  • 1033 Answers
SOURCE: Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Posted on Nov 08, 2012
Lennox furnace model G11Q3-110 v.2 burners light but go out before fan comes on
Troubleshoot an ignition problem on a Lennox gas furnace ...
? 2:44
https://www.youtube.com/watch?v=yXIxgzwMkPs
Nov 17, 2012 - Uploaded by grayfurnaceman
This furnace should light its pilot with a spark then the pilot proves its on ... Troubleshoot an ignition problem on a Lennox gasfurnace .... Pilot and no inducer but is the same model as that great video! ... You probably have dirty burners. ... How do you know spark module is not sending 24 volts to mv and pv ...
Lennox Furnace Model G11Q3-82-2 - RepairClinic.com
Nov 19, 2012 | Heating & Cooling
Nov 08, 2012 | Heating & Cooling
Ruud 90+ Model UGRA 10EZAJS Trips Out
Check for condensation buildup in the Induction Blower housing. The condensate tubes or canister may be blocked and causing the diaphragm switch to trip the unit out causing the burners to shut down.
Feb 11, 2012 | Ruud Heating & Cooling
Have a Fridgidaire GR6C-080C-16 furnace that runs for a few minutes then gas supply is cut-off. Furnace will then re-start and the run through it's pre-cycle, just as if the thermostat just called for...
It sounds to me like you have problems with the gas valve as you have eliminated pretty much everything else. I would check all wiring to valve,check for any breaks on the insulation and clean all connections.
When the burner goes out is the blower still running or does it quit then the burner go off? If that is the case I would think the thermal overload on motor was tripping. It makes me more inclined to suspect the gas valve due to the lack of any diagnostic code.
One other thing I would try is to check power to gas valve when burner is firing and see what it does when it cuts out.If it maintains power when gas shuts off then I would replace gas valve. Good luck and thank you.
Feb 14, 2011 | Heating & Cooling
Hello, I have a Amana Air Command 80 model #GHI90A50, 22 years old. This furnace is on its third ingnition module (last one two yeras ago). The symptom I am trying to diagnose has been ongioing since this...
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 05, 2010 | Heating & Cooling
Lennox Model G12Q3-82-1 Gas Furnace pilot light extinguishes each time butrner cycles off afrer heat cycle
Hello,See if it is blowing out.Relite the pilot and run the fan(blower) with out the main burner running.A cracked heat extanger will be the cause if it blows out.
Oct 29, 2010 | Heating & Cooling
Carrier Gas Furnace and Hunter Thermostat not working
Definitely a furnace issue. The gas valve is not opening if you see no flame. I have seen the igniter glow but not send enough voltage to the circuit board to make the gas valve open. If this is the case you should replace the igniter. It is very fragile so please use care when replacing. Check all connections at the circuit board as well as the gas valve. Check your gas supply. Check to see if you get 24 volts AC to the gas valve. If no, replace the circuit board. If yes, replace the gas valve once you confirm that you have gas to it. If you get a pilot flame only, you will need to clean the burners and flame tray that spreads the flame from one burner to the next.
Dec 06, 2009 | Heating & Cooling
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
I have a Lennox furnace. The pilot light is lit, but the burners do not ignite...no heat to the house as a result
You have a multitude of things it could be.From a open safety switch to a bad gas valve. I need to know what the model number is on the furnace. You can find that by opening the door where the burners and gas valve are and it should have a sticker in it giving model # and serial# . Once I have that I can help you. David- HVAC TECH
Feb 01, 2009 | Heating & Cooling
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Heating & Cooling Logo
80 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
