Question about Casio Parts Cash Register PC Desktop
I have till t 500 casio suddnly stop working prodict keys main left hand side 12345678910 are working
  • 737 Answers
Hi. I assume you mean a TK-T500. The model you gave seems incomplete.
Do the flat buttons give a beep when pressed? Is the menu sheet holder still on the same side it always was? (there is a number at the bottom of the holder. This must be showing the same number as it did when working).
If nothing happens at all when you press them, then the membrane inside the keyboard has usually suffered liquid damage. The keyboard will need to be taken apart and soaked if this is the case. Look under the holder and see if you can see any signs of liquid.
Mark
Posted on Oct 23, 2008
Why isn't it working?
It may have lost the program. Has the battery been replaced on time? You need the dealer codes to program it. One of the users has the dealer codes in this manual:
https://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
Aug 22, 2015 | Casio TE-4500F Electronic Management Cash...
I have taken over a pub with a casio tk-2300 till. The keys down the right hand side are programmed with the staff's names so that they use their own log-on when they ring something in. How do I...
It is called clerk name programming. Usually in the program 2 section of the manual. Run through the tables and find the memory numbers for the clerks. -------------------------------------------------
If anyone needs more information, the Casio TK-2300 manuals are here: http://the-checkout-tech.com/manuals/cashregisters/Casio5.php
Sep 06, 2011 | Casio Parts Cash Register PC Desktop
Hi i was using my ipad, and i connected to laptop. thn aftr it suddnly got dead, till nw its not working. i had 20 percent battery
Does the ipad charge when in the mains power?
It might be in safe mode, press the power and home buttons together for around 10 seconds, then the power button alone and see what happens,
Mar 03, 2011 | Apple iPad (16 GB) WiFi Tablet PC
I want to change time zones on my casio edifice. I can't work it out.
Press the button on the top left-hand side of the watch until the display shows the current hour and the letter "P," "M," "C," or "E" which indicates the current time zone. (Pacific, Mountain, Central or Eastern.) If the time zone is not correct, press the button on the top left-hand side of the watch until the correct time zone is displayed.
Feb 28, 2011 | Casio Watches
Ricoh MP4000 error code SC441 how do to solve this ?
SC 440/441 Main motor Lock/Main Drive section Jam
tray You the condition
01. Press Clear/stop Key (Yellow Key) 2 tarms
02. type 107 same time
03. Press hold down clear key 5 secend ( red key)
Belinkin 1 on the copy counter left hand side
04. type 5 and press # ,type 810 and press #
05. tarn of the machine and tarn ON the machine.
nasmamtrade@yahoo.com
088-01710-950 340
Jan 20, 2010 | Ricoh Office Equipment & Supplies
Casio JF-100TE Battery Replacement
Remove two screws at top. Then there are 3 hidden **** on both the right and left side of unit for a total of 6. Pry the case apart starting at top on one side. Then slide a small thin screw drive down the side till you come to first *** and pry just a little till it comes apart. The first *** is on the side at display height center. The next *** is between the GT key and division key on side. The next *** is on side at top of plus key. The case will now swing open like a door with the same 3 **** on on side of case. The top of case **** are female. The bottom of case **** are male. The battery slides in and out. Make sure you get + and - right.
My problem is I changed the battery but display still only works with solar power.
Jan 22, 2009 | Casio JF-100TE Calculator
From left hand side 10 keys not working
You might check settings first. The keyboard might be set to a mode where those keys have some function besides notes. Try a master reset and see if hings start working.
If it was working and now those keys don't, a fault has probably developed. There may be problems with connections to the keyboard, or there's been a component failure.
Sometimes getting into these things and accessing the keyboard is a challenge, and it's possible to do more harm than good. If it needs repair, you're probably better off taking the keyboard to a musician's store in your area and asking them to give you an estimate for the work (or to recommend a servicer if they don't do the work themselves).
Nov 26, 2008 | Casio Ctk 496 Electronic Keyboard with 61...
Casio em-500 deleting mail programs!!!
I believe they are in unit's ROM, which is non-reprogrammable. Hence, you won't be able to delete anything from there. On the positive side, they don't occupy your main memory, so there's really no harm in letting them dwell in your PDA. :)
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
Casio Parts Cash Register PC Desktop Logo
113 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
