Question about Home
Need to buy a bellavista stylo whilte d shaped toilet seat
Can anyone advise
3 Suggested Answers
  • 102 Answers
SOURCE: I have a square shaped toilet and need to replace ...
Check with your local plumbing supply houses. I believe Kohler and Eljer noth made square front bowls at one time. I hope this helps.
Posted on May 21, 2010
  • 8 Answers
SOURCE: Toilet seat too loose
Is the nut thats on the under side fastened all the way and If you've done that and the screw keeps getting loose then the threads inside the nut or on the screw may be worn away. If thats the case, you may have to by some new screws and I'm not sure if they sell those separately you would usually have to buy a new toilet seat to get new screws, but try home depot or walmart.
Posted on May 10, 2013
Trying to find a replacement toilet seat for Bellavista Stylo white toilet in Sydney Australia
I had this problem also. Reece Plumbing sell replacement soft close seats, as do Bunnings. Also call Ostar International116 Milperra Road, Revesby NSW 2212 Phone: (02) 9773 3788, to see if they can assist.
Make a cardboard outline of the top of the bowl to match the geometry.
Oct 02, 2015 | Home
Where is the serial number - toilet is 25 yrs old and need a new toilet seat.
Typically there is no serial number associated with a toilet seat. The seat will either be a round front or an elongated seat. Just make sure the shape is the same when purchasing the replacement seat.
Jan 20, 2015 | Porcher Home
How to install a u shaped toilet seat
Remove old by loosening nuts from under rear of seat and reinstall new seat in the opposite
Aug 10, 2014 | American Standard Church Seats EL270...
Toilet seat gural vitrifiye
I need a toilet seat.
The present one has the words GURAL VITRIFIYE on the lid.
It is a D shape and has concealed rubber fittings.
The hinge sockets are 19 cms apart.
The seat is 35 cms wide and 45 cm max length from front to back.
Thanks.
Can you advise please?
Jan 04, 2014 | Liebherr European Right Hinge Fully...
Bellavista stylo toilet
Hello.
I live ind 18690 Almunecar, Andalusien, kan you help me with where I can by a new toilet seet.
With Kind regards
Mogens Madsen
Jun 06, 2013 | Home
I have a square shaped toilet and need to replace the seat. Where would I find one?
May 19, 2010 | Home
Have to replace two new toilets seats,the seats move
Martin, Jacuzzi has a one year warranty on toilet seats so if you have defective seats and they were purchased less than a year it is covered you will have to find a dealer near you, I provided a link for you to accomplish this. How is the seat attached? There should be two plastic screws with a nut on the underside which can be tightened these tend to loosen and nee re-tightening every so often. I hope this has helped. Thanks for using FIXYA, good luck and have a great day. Jeff
Find A Jacuzzi Dealer
Apr 07, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Me top just broke
two screws at back of seat is two square caps lift caps there is either two philips screws or two flat head screws when you grab screw driver get a pair of pliars to hold nuts on bottom of the screws hold the nuts as you are loosening the screws then just go to the home depot or supply store you like get toilet seat that is egg shaped buy and put in old ones place
Mar 11, 2010 | Ergo Toilet Seat - Elongated -Curve -...
How to fix loose toilet seat on old blue toilet
Whether the bolts are nylon or brass, they all come loose after a while. The culprit is oversize holes in the china bowl. To solve the problem, go to the auto parts store and buy a short length of fuel hose, just large enough to slip over the toilet seat bolt. Cut two short pieces of hose off -- about 1/4 inch each -- with a sharp bread knife or utility knife. Fit the pieces of hose into the toilet seat mounting holes in the bowl. If the hose is too large, snip a small segment out of it to make it into a "C" shape, just large enough that the cut ends touch when inserted into the mounting holes. Install the seat as usual and snug up the nuts.
Once movement of the seat is prevented, the bolts tend to stay tight. I've performed this trick on a number of my own and friends' toilet seats and they've stayed put for 8-10 years with no signs of loosening, yet can be removed easily for maintenance and cleaning.
Use fuel hose, as it is durable and does not deteriorate with exposure to air. This trick won't work with electrical tape, duct tape or masking tape, as those materials are too soft and the adhesive cold-flows under pressure.
Aug 14, 2009 | Crane Plumbing Home
The self-lowering mechanism of my Laufen Pro toilet seat is broken, how can I fix it myself?
The pneumatic cylinder that controls the lowering probably needs to be serviced or replaced. Here is a link to the manufacturer website:
http://www.laufen.com/export/servlet/portal?codpage=productsresult&planguage=EN&ppais=EX&sesid=2302425382030&tipo=3&dlvalue=01A1&psgvalue=0008&dltxt=LAUFEN+PRO&psgtxt=WC-SEAT&radio_ch=&designline=01A1&productsg=0008
Mar 27, 2009 | Home
Home Logo
221 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
