Home | NEC | SuperScript 1400 Laser Printer | Red light stay,s on
NEC SuperScript 1400 Laser Printer
Problem for NEC SuperScript 1400 Laser Printer
Red light stay,s on
By Benn40 on Aug 04, 2006
My printer is indicating that there is a paper jam,the red light is on and my printer will not respond.I have done everything the manual suggested but nothing seems to work.
Please help.
Same Problem
Feb 12, 2008
-   phantom paper jam faults.
-   Guest
Feb 11, 2008
-   Red light stays on and printer will not print. I have shut down the PC and Printer on numerous occassions and the light still does not go out.-   MerryJAY
Jan 22, 2008
-   My hp officejet dl 55 xi has a mind of it's own!
When I try to copy, I get the message:
open carriage door, clear paper jam, and then press enter
I do, -- no paper jam--, close and press enter - then
it shows copying 1 of 1, but nothing happens.
press enter, it shows busy & goes back to copying 1 of 1
press copy, it shows busy & goes back to copying 1 of 1
sometimes it goes beep, beep, beep when buttons are pushed.
It cannot be shut off with the power button, it must be unplugged when it is doing this.
Help!!!!!
Ann
-   Selleck
Jan 09, 2008
-   red light stays on, have done everything without results-   Guest
Dec 15, 2007
-   where is the paper feed sensor on an HP Photosmart 7960?-   Bichon
Best Solution
posted on Jan 20, 2007
Very Helpful)
tomj23
Rank: Guru
Rating: 87%, 1799 votes
Benn40,
You didn?t say but I?m assuming you?re getting a status code error, which indicates where the printer thinks the jam is located:
E2 = copy paper has misfed; refer to page 36 for clearing instructions.
A1 or A2 = single pass feeder; refer to page 37 & 38 for clearing instructions.
If you don?t have your manual you can download a copy from the Xerox site here:
http://download.support.xerox.com/pub/do...
As was mentioned in an earlier post you?re going to have to carefully scan the paper path for paper remnants that may be covering your sensor. If you?re positive nothing is blocking the path then its likely a sensor or perhaps a controller board has failed. That will likely require a trip to the local authorized Xerox repair shop.
Hope this helps and please don?t forget to rate this posting.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 11, 2007
Somewhat Helpful)
Inky
Rank: Guru
Rating: 85%, 926 votes
You can also try feeding a piece of A4 card backward through the mechanism. Be careful not to get too close to the right hand side as you could damage teh paper sensor.
Tip the machine on it's back and gently feed the card backward through the rollers ath front and between the main feed roller and the smaller pinch rollers. Once throught the pinch rollers, pushe the card steadiley back. If you meet a bit more resistance be carefull. Pushing too hard may cause more damage - you may be pushing against the sensor paddle. Move the card left a little a keep trying.
You may find a paper clip, piece of paper, old coin, toy soldier or many other things fall out of the back.
Was this helpful?
Yes
No
Solution #3
posted on Aug 06, 2006
Somewhat Helpful)
zaak
Rank: Guide
Rating: 78%, 108 votes
Look closly to see if a bit of paper (or paper scrap/dust) has built up around the paper feed sensor. If so clean it and see if that helps.
Zaak
Was this helpful?
Yes
No
Solution #4
posted on Mar 05, 2007
Somewhat Helpful)
jenturner
Rank: Apprentice
Rating: 59%, 2 votes
I'm sure you've taken a hammer to your printer long ago, but I think this will fix the problem if you haven't. I went crazy with my hp3930 - it always thought it had a paper jam no matter what I did to convince it otherwise. I did the restart/on and off/cancel jobs bit - none of that mattered. Here's the deal - the HP3930 is a really wierd printer. If you load the paper in normally - IT WILL NOT WORK CORRECTLY - it will intake a bunch of sheets instead of 1 at a time, if you can get it to print at all. The solution - don't give it too much paper and don't put the edge of the paper stack very far into the tray. Just put it in far enough for the printer to be able to pick up the paper - any farther and this printer won't work for you.
Was this helpful?
Yes
No
Solution #5
posted on Oct 16, 2009
Not Rated)
Skibum8183
Rank: Apprentice
Rating: 0%, 0 votes
Paper jam in C8180 got all paper out, but still is jammed. Solution
Was this helpful?
Yes
No
Solution #6
posted on Mar 01, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Very helpful!
Solution #7
posted on Feb 24, 2007
Not Rated)
sher singh
Rank: Apprentice
Rating: 97%, 193 votes
printer cartridge damaged.....put your cartridges in another printer and see if that printer works or not? and put the cartiridge of that printer into your printer...see of your printer is working or not?...if it works then problem lies in your cartridges....
Was this helpful?
Yes
No
Solution #8
posted on Jan 15, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
remove and check right cartridge
Solution #9
posted on Jan 14, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
When I go to print the printer pulls the paper over half way down in the printer before it prints so the whole top half of the paper is blank.
Solution #10
posted on Sep 07, 2006
Not Rated)
Lensman
Rank: Apprentice
Rating: 0%, 0 votes
Yes, but where is aforesaid sensor???
(Sorry it's not a solution. I can't see how to reply to an answer)
Was this helpful?
Yes
No
Popular Solutions for NEC SuperScript 1400 Laser
Questions and Unsolved Problems for NEC SuperScript 1400 Laser
Do you recommend NEC SuperScript 1400 Laser Printer?
Answer
Answer
The output does not match the print preview - one page only prints on about 1/2 sheet of paper
Answer
My print server crashes with an error message BAD POOL HEADER when trying to print certain web... (More)
Answer
We have a NEC 1400 hooked up to our main computer (XP) and printer sharing turned on. Our daughter... (More)
Answer
Margot603@sbcglobal.net The left light stays on.
Answer
I am having problems with paper jams on my xd155df printer. I can put soap on the pick rollers allow... (More)
6 Other Users Have The Same Problem - Continued
Comment by erasmo, posted on Nov 23, 2007
Where is the paper feed sensor and how does it look like?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For NEC SuperScript 1400 Laser...:
Top Printer Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
