Question about Eclipse (XA1000) Car Audio Amplifier
Pairing my eclipse bluetooth
Having problem pairing my eclipse hands-free bluetooth with my verizon blackberry curve 8330?
CAN'T GET MY BLACKBERRY 8330 TO PAIR WITH MY
Did you do the steps listed here?
This is the Plantronics information.
Your new headset includes Plantronics QuickPair technology to simplify
the Bluetooth setup process. The rst time you turn your headset on, your
headset automatically enters pairing mode for 10 minutes. Once paired
successfully, your headset stays on for instant use.
If not sucessfully paired after 10 minutes, your headset automatically
powers o. When you turn the headset on again, it automatically goes
into pairing mode until successfully paired with a Bluetooth phone.
To pair your headset for the rst time:
Turn ON the Bluetooth feature on your phone.
TIP: For most phones, select Settings/Tools > Connections > Bluetooth > On.
See your phone’s user guide for more information.
Press and hold the call control button to turn on your headset. (The indicator
ashes red/blue to show that the headset is on and in pairing mode.)
TIP: If you don’t see the red/blue ash, press and hold the call control button to
turn your headset o, and then press and hold the call control button again until
you see the red/blue ash.
Use the commands on your phone to locate your headset.
Search > 520Plantronics. See your phone’s user guide for more information.
When prompted for the passkey, enter 0000.
When pairing is successful, the indicator on your headset ashes blue. Your
headset is now connected and ready to use.
Apr 15, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
My curve will not recieve ringtone data transfer when pairing with other phones
The trick with pairing on the blackberry is that the person receiving the file has to allow the file at the same time the sender is initiating the send. This is a security issue with bluetooth on the curve. Once you get the tone you can look at this guide to get everything else setup.
http://www.exectones.com/blog/60-seconds-to-install-ringtones-on-your-blackberry/
Professional Ringtones:
Mar 13, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Trying to pair a h12 bluetooth to the 8330, asks for numeric pass key. i have tried 0000 and 1234 it says unable to pair
Is the blackberry in pairing mode? Is the earpiece in pairing mode? They both need to be set. Four zeros should be the passkey.
Oct 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
I am trying to sync a new bluetooth (sprint brand) to my blackberry curve 8330 I have bluetooth enable and have searched to locate the bluetooth earpiece and it keeps saying can't be found
You have to make sure the bluetooth is in a pairing mode for the blackberry to discover it on most bluetooth they have a pairing button turn off your bluetooth headset hold pairing button till the light is solid or flashing red and blue depending on model then search for new should find it
Sep 24, 2009 | Cell Phones
Blackberry Curve 8330 can not find my bluetooth headset
Turn the 360 off.
Then turn Bluetooth off, then back on the Curve.
Then turn the 360 back on, input the code when asked to due so.
Jul 23, 2009 | RIM BlackBerry Curve 8310 Smartphone
Won't pair with Motorola HS850 headset
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Pairing Jabra BT4051 to my blackberry
I paired my BT4051 with my BB curve just fine. I held down the power button on the Jabra until the blue light was solid and then added the device through my BB's bluetooth setup under options.
Jan 17, 2009 | Cell Phones
Connecting to bentley bluetooth
Try the default codes 1111, 0000, 1234. Make sure that your Bluetooth Headset is in pairing mode and that your Blackberry is set to on and is visible to all devices.
Dec 17, 2008 | RIM BlackBerry? Curve 8330 Cellular Phone
Eclipse (XA1000) Car Audio Amplifier Logo
95 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
