Question about Craftsman Garden
Craftsman 6.75hp 22 mower starts for a few seconds and concks out
Mower starts for a few seconds after bulb is pushed 5x's. Mower then concks out. I took out the carb, took it apart, cleaned it up, and I'm still getting the same result, the mower wont stay running.
If the carbeurator is pitted or corroded in any way you need a new carbeurator
Steve's Small engine repair & Blade sharpening
Jacksonville. Fl
Posted on Feb 12, 2013
5 Suggested Answers
ccrozier_agr
  • 36 Answers
SOURCE: broken starter cord lawn mower #944.368300/craftsman
Please note ! patients is required with this one !
Hi, remove the recoil top cover with the recoil attached. ( DO NOT TAKE OUT THE SPOOL OR YOU COULD HAVE THE SPRING GET YOU IN THE FACE)
Remove old cord.
With your new cord lace it through the recoil spool centre hole with a knott on the end.
now depending if the recoil winds in clockwise when spool is facing you wind the cord around it a few times by turning the spool clockwise,
Then put the cord in the notch at the side of the spool & wind the spool & cord anticlockwise about twice the number of turns of cord (this should tension the spring).
Take your end of the cord & lace it through the hole outside of the casing & fit you pull handle.
But hold the spool firmly untill the cord has a good knott on the end of it.
(Sometimes I see the guys here putting a loop in the cord to stop it sliping in while they tie a knott on the end of the handle.)
Posted on Nov 29, 2008
  • 10865 Answers
SOURCE: won't stay running
The carbeurator needs to be cleaned and probably rebuilt. Start with a spray carb cleaner by putting 3 or 4 shots in the carb. Run it for a minute then let it sit for two hours and run it again.
Posted on May 07, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
  • 89 Answers
SOURCE: craftsman lawn mower wheels won't turn
take cover off the top off deck and see if your belt have came off next turn deck sideways but before you turn it sideways take air filter off cause oil can come through and ruin the filter noe look and make sure the belt is on the pully
Posted on Nov 04, 2009
My push mower starts then revs and slow every 1.5 to 2 seconds. What would cause that?
It sounds like your engine is "surging". I believe that mower has the plastic carburetor that sits directly on top of the fuel tank. There is a diaphragm and gasket that go between them and if they get old and tired or get a pin hole in them, that will cause the engine to surge. If you're mechanically savvy, you can replace these parts yourself. If not, you'll need a shop to do it. The item you need can be purchased at Lowe's and retails for $2.98. It is Item# 219691. Model# 5083D. Hope this helps and best of luck to you.
James
PS. here's a direct link to the page:
http://tinyurl.com/5tgnxtl
Sep 14, 2011 | Craftsman 55 Torque 158cc 22" Push Lawn...
Craftsman 917373981 will not start unless keep pushing the primer then floods could figure it out if i had a
I have had two problems with this type of mower. The first is if the mower has gotten wet, the screw that holds the fuel bowl on has a small hole in it that can plug up. The second is that there is a line I believe from the carb to the crankcase than goes bad. Hope this helps.
Sep 12, 2011 | Craftsman 22" Rear Bag Rear Propelled High...
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
22" Rear Bag Rear Propelled High Wheel Lawn Mower (): I can't find the manual -- how do I start the mowe...
Fully depress primer bulb only 3 times, then pull starter cord. Ensure air filter is clean and gas is fresh before attempting to start.
May 16, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Replacement part for Craftsman 650 Briggs & Stratton 22" multi cut mower Model #917.376741
You first need to locate the model number on the mower, not the Briggs engine. Then go to searspartsdirect.com and enter your model number on the right side of the web page. This will take you to a list of parts for your mower. Your model number should be located on the deck of the mower (you didn't say if it was a rider or a push). Rider model numbers are located on the rear of the body behind, on or under the seat. Push model numbers are found on the back of the deck between where the handles attach to the frame.
May 25, 2009 | Craftsman Garden
Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
May 18, 2009 | Craftsman Garden
Push mower runs then quits!!
My toro mower starts and will run for ablut 15 minutes and starts to cut out and eventually stop running. What could be the problem
Apr 01, 2009 | Craftsman Garden
Garden Logo
135 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
