Bosch 24 in. SHU43 Built-in Dishwasher
Problem for Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher keeps running
By Kirby on Aug 04, 2006
My Dishwasher runs for about 4 hours. It keeps washing, then goes to the rinse and dry cycle.
Same Problem
Nov 24, 2008
-   I have the same long running problem. My hot water is getting to the dishwasher (130 degrees), but the water temp inside is still kind of cool (90 degrees). Then it just gets colder the longer it runs. I assume that it is either the board, as someone pointed out, or the heater itself. How can I check to be sure which one it is? Where are these two parts located within the appliance? -   davgotden
Jul 22, 2008
-   My Bosch SHU3136UC dishwasher is doing the same thing. We haven't changed the settings on the water heater. Where is the control board if I need to check it out? -   skimomcathy
Nov 11, 2007
-   I have the same problem. My Bosh has been running for at least hours.-   boops
Best Solution
posted on Nov 05, 2006
Helpful)
Rotu
Rank: Guru
Rating: 90%, 607 votes
I have seen this several times, and all of the times it has a bad control board. usually if you take the control board out, you can see a visibly burnt spot on the back of it wher a connection has melted. Another possible slowrun time problem could be that the water coming into the dishwasher when it fills is not hot. If it isnt hot, it takes the dishwasher longer to heat the water to temp, and therfore it runs longer. Is the water coming out of your tap reasonably hot? if not you may need to turn up your water heater settings. But if nobody has messed with the water heater, or the tap where the dishwasher is attached and the problem just started then thats probably not it. Good Luck!
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Feb 13, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My dishwasher counts down to 1 minute and is stuck there. If I open the door it starts back at 30 minutes and does it over again.
Solution #3
posted on Mar 28, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My Bosch dishwasher had a faulty (undoubtedly from the Siemens factory) solder joint on the load connections of the heater relay in the timer. I cleaned and properly soldered the connections and its worked fine since. (this requires disassembly of the timer assembly). Also noted that additional cycles of more expensive models appear to just be a matter of changing programming jumper on timer.
Popular Solutions for Bosch 24 in. SHU43 Built-in
Questions and Unsolved Problems for Bosch 24 in. SHU43 Built-in
Do you recommend Bosch 24 in. SHU43 Built-in Dishwasher?
Answer
Answer
I have gone through most of the wiring (besides removing the bottom and inspecting the motor) and... (More)
Answer
Door makes a loud grating sound when door is opened and closed.
Answer
it does not let in water to the machine ,the sound is normal when its plugged on,the lights are on... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
