Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Part broke off and I can not identify it
Paper won't feed so can not print after a small (about 2" long x 1" wide) white plastic piece fell out o my MFC-240C but i don't know what it is and can not find a parts list on-line---any idea what this is and how i can re-attach it to get print capability back?
  • 21 Answers
I have my MFC-235C (same but for LCD screen and card reader) dismantled on my table right now.
On the bottom of the printer , after I have removed the printer tray there is, from 3/4 of the way to the back of the printer, to the back of the printer, a base sheet of gray plastic.
This is shaped in a wide "V" with the apex towards the back of the printer.
In the apex of the "V" is a white plastic coomponent with 2 hooks towards the front and a flap towards the back.
It is fixed between the two grey wheels and appears to just clip onto the outsides of the black plastic fins that are on each side of the white plastic gear-wheel that is in the centre of the apex on the printer base.
You may find it easier to see how to replace it from the back of the printer. There is a shield there that is removable in case of paper jams.
The white plastic appears to have some sort of "spring" occuring. But I cant see if that is built into the white plastic component or something external.
DIAGRAM OF BASE OF PRINTER: "V" marks location
front
oooooooooooooooooo
o o
o o
o o
o o o o
o V o
o o
oooooooooooooooooo
back
Posted on Nov 05, 2008
Printer jams only when I put paper into the tray, and not when I feed the paper manually
in your paper feed tray there is a paper separation pad which is setup on a spring.just scratch it with some fine sand paper and clean with IP solution.
May 27, 2012 | Brother HL-2040 Laser Printer
Says paper jam no paper in machine
HI,I had the same problem today. I ended up taking a piece of paper and from the back side started lightly forcing the paper in the back slot. I had the top cover open where you replace the ink cartridges. Towards the back you can see the paper start coming into the printer next to some rollers. On mine there was a small black switch about an inch from the right in the middle of the plastic piece above the rollers. Once I started pushing this paper in I could see this switch was stuck in the down position. After several minutes of pushing the paper in and out the switch moved up and out of the paper path. I then pulled out the paper and hit the ok button and it came on line. This may work better with a piece of card stock.
That switch is the issue. I ended up finding an object lodged against the switch. Needed a flashlight, plastic giftcard and a tweezers to get it out. Works great now.
Also,open the printer where the paper for printing is put in.
At the back left hand side there is a white long piece and either side a white piece with a small square on it.
Use a longingish screwdriver and push this gently down. It will click back into place quite easily.
Note: this tops the paper from feeding in and needs reseting after a jam.You will know all is OK when a sheet of ordinary paper is put in > touches the feed roller above the white bits, and is level across the paper feed area.
Hope it helps,,
Thanks for using fixya.....
Nov 22, 2010 | Canon PIXMA MX310 All-In-One Printer
While removing a paper jam a white plastic piece fell into the paper feed area. It appears intact, but I cannot work out how or exactly where to re-attach it. The printer cannot feed the paper correctly...
This white plastic pease is from Paper Out Chut, There are two latch to fix it, If you can , Other wise you have to open the cabinet and than only 'you can fix it.
May 02, 2010 | Brother DCP 165C Compact Color Inkjet...
My granddaughter put a toy in printer & a part broke off - thin, translucent piece about 1/4 inch wide by 7 inches long. How do I open up the printer in order to try to put this part back?
The plastic piece you are talking about it just prevents the paper from bending forward when is inserted in the printer. That plastic piece should not cause any paper jams or printing problems. If you do happen to have paper jams maybe a piece of plastic fell inside where the paper goes. Simply turn off the printer, remove the paper and flip the printer upside down and shake it a little that should remove any debris inside the printer.
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
A small white plastic part that is part of the
it is really difficult to identify what kind of part you are referring to, the only thing you can do is to took a snap shot and send this to a shop.or bring the part itself.
I think this part came from the feeding assembly, most part came loose after a period of time
Nov 19, 2009 | Brother MFC-5460CN InkJet Printer
Canon MX310 paper jam
"Gclanton" had it right.
Nov 24, 2008 | Canon PIXMA MX310 All-In-One Printer
Plastic piece came out, where does it go?
very good you explanation is correct the tab is part of the paper feed section you will have to figure out how to slide the plastc under the spring some how. normally the machine is taken apart. the reason for the part coming out was from the paer jam. if you need more help let me know i will try and help brother tech
Oct 07, 2008 | Brother MFC-465CN InkJet Printer
MP470, Paper jam on one side
There is something jammed in there....shake it upside down first.....if nothing then revese feed a paper through it manually......take left side off hold paper in front and roll wheel on the left side so the paper feeds back into the machine,,,,,,open top to see in there and when paper feeds under white rollers make sure it dosent jam where wite rollers are about an inch from the right there is a small rectangle hole with a black plastic piece in there pry it up carfullywith a paper clip and feed paper with the wheel under it at that point the paper push out a bobby pin into my back tray,,,,, now everything works great.......keep checking i didn't believe something was there either but there was..... also if your paper first starts to feed and stops pull out the paper and check for a bend or crinp in it mine kept doing that and that is exactly where the pin finally came out.....
Feb 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
134 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
