Question about Miele W435WPS Front Load Washer
How to change brushes on a miele washing machine
5 Suggested Answers
  • 16 Answers
SOURCE: miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Posted on Feb 08, 2008
  • 1122 Answers
SOURCE: Separate miele washing machine and dryer
if you go to sears .com click on parts put your model number in(should be inside dryer door)it willl break down and show you everything you need to know,let me know how it turns out,mike
Posted on Sep 28, 2008
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
  • 70 Answers
SOURCE: 10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Posted on Jun 19, 2010
Miele w911 washing machine Main Wash light flashing. Replaced carbon brushes. Machine needs kick start or ???
carbon brushes r black as, well, carbon. They need replacing when they r worn not blackened.
try something else
Feb 18, 2015 | Miele Washing Machines
Miele w562 brushes
Can you be more specific about the problem? They are readily available from Meile or a well known auction site. Fairly easy to change.
Dec 28, 2012 | Miele Washing Machines
Brushes on miele 562 machine
Your question is not very clear but I will try to help you. If you need the brushes for the electric motor need to be replaced, you can google parts replacements for your machine, or go to the Miele Company on line and request the parts for your particular model.
Dec 28, 2012 | Miele Novotronic Premier 500 Front Load...
How do I open my Miele W504 and change the motor brushes
Hi Kieron
Open door then turn off power. Undo 3 bolts around door seal. Remove soap draw. Undo the screws. Peel off door seal at front of machine and fold in towards drum. Metal spring catch located at bottom behind pump filter door. Now open up front of machine (its hinged on the right). Good luck
Feb 19, 2012 | Miele Novotronic Premier 500 Front Load...
Jun 15, 2010 | Miele 300 Front Load Washer
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
May 21, 2010 | Miele W865 Front Load Washer
Rinse light flashing on miele novomatic washing machine
Check the motor for worn brushes and or noisy bearings while it is removed for service. Any auto mechanic should have experience replacing brushes and bearings. Much cheaper than ordering a new motor. New brushes and bearings should cost around $30. The shop time should not exceed one hour. Miele charges about $50 for brushes if you can not find a local supplier. The W1930 motor that I rebuilt used a 6202Z and a 6201Z bearing set.
Sep 02, 2008 | Miele Touchtronic W1213 Front Load Washer
Miele W435WPS Front Load Washer Logo
20 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
