Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Oil is leaking from the rear end of my craftsman mower
3 Suggested Answers
  • 138 Answers
SOURCE: Craftsman Won't Start
i think i'd look for a new repairman - did you check the oil? maybe he didn't put any oil back in it! or maybe the carb float stuck and the crankcase is full of gas. lift the hood and look for burnt wires or at the deck for a burnt belt - try to turn the engine over by hand [the round center with the perforations]. does it click when you try the key? if, not, check the fuse. without knowing the area that the smoke came from it's hard to single out a cause
Posted on Aug 22, 2009
  • 146 Answers
SOURCE: Oil leak on riding Craftsman LT2000 (Kohler)
Fortunately, the engine oil doesn't go through any rubber hoses, so they are mouse-proof. The oil probably leaked out through an engine seal. Oil on the engine surfaces would smoke when it gets hot. Check your oil level and top it up if necessary, before you run the engine again. The engine can run fine even with a slow oil leak; you just have to watch the oil level from time to time. The leak could be easy to fix - by tightening up a few bolts -- or expensive.
The gas runs through rubber hoses, though. If mice ate through that, I think you would have smelled the gasoline, and the engine wouldn't run for more than a few seconds. But if you see a severed hose, you should replace it. Take it off and bring it to a mower shop or auto supply shop, and buy something the same diameter. Inexpensive.
Hope this helped! If so, please rate my answer, thanks!
Posted on Jun 07, 2010
Testimonial: "Whew, you've eased my mind. I'll head out tomorrow and try your suggestions. I really appreciate your input and the fact that you are willing to respond! Thank you!"
I need to add oil to rear end it has leaked out
If you a peer. transaxle, you have a fill plug on top to fill with 80/90w.
Sep 11, 2013 | Craftsman Garden
I have a Craftsman lawn tractor and am getting oil leaking around my rear wheels. How major is this problem and how do I fix it?
you need to remove and split the rear axle and thats if you can get the rear tires off from the axle
Aug 03, 2012 | Craftsman Garden
Oil leak in front lower end on 22 hp intek motor
Is the valve cover leaking? The only place besides cover
would be the gasket between block and sump plate
, lower engine. Alot a work there, leaking bad bad.
Jul 29, 2012 | Craftsman Garden
I have a Craftsman 17.5 hp 42 in.cut riding lawn mower that I've had for about 5 years now, and the rear end is starting to make a whinning sound..How do I grease, or oil the rear end?
It a sealed unit. No service needed. They said call service provider. You tear it apart, if you want. Remove axle from mower. The case unbolt in two pieces>
May 08, 2012 | Craftsman Garden
Smoke is coming from the engine
It is worn out and needs repair or has a oil leak and needs repair.
Apr 21, 2012 | Craftsman 22" Rear Bag Rear Propelled High...
Started to vibrate and stopped working when I passed over roots.
you had the mower up on it's front oil leaked in the head take the plug out and pull it a few times to clear the oil out and clean the plug it should take of the problem
Jun 26, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
I have a Sears Craftsman mower with Tecumseh, major oil leak
On many Tecumseh engines, there is a crankcase breather located under the flywheel. It has a cork gasket to seal the top plate of the breather. Either the rubber breather housing is cracked, or the cork gasket needs replaced.
Nov 07, 2009 | Craftsman Garden
I need to find a repair manual for a craftsman riding lawn mower
SearsPartsDirect.com should have your answers
Apr 26, 2009 | Garden
Lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
130 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
