Question about Electric Air Tools & Compressors
Westinghouse air compressor model 3yc
Westinghouse 3yc
2 Suggested Answers
SOURCE: Howdy, I just acquired an air compressor,
We have a Westinghouse 3YC air compressor. The safety relief valve in the line between the two compressors started "popping off" recently. The compressor seems to be working fine. Is this a problem only with the relief valve or could there be a symptom of a more serious condition that we should be attending to? The valve is stamped 60 max which I assume is 60 psi. Is this the correct size. The tank pressure is set for125 psi. The tank relief valve is marked 250 max.
Posted on Sep 25, 2011
Have a old (1950's guessing) westinghouse air compressor. Pumped it to 150 psi, I shut off, air was coming out of air intake and had pressure in the crank case.
replace the non-return valve in the pipe at the tank connection
air out of intake is poor poppet/read valve seating and pressure in the sump is the tank air leaking back and down past the rings
150 psi is excessive and not good for the compressor so adjust it back to 100 -110 psi
Nov 12, 2016 | Air Tools & Compressors
Toyota 3yc engine timing
Rotor button needs to be facing number one cylinder ,with crank shaft timing mark on TDC Markings are visible on plate.Note all marks have to be lined up.before starting engine otherwise valves will be damaged if markings are not lined up.#3yc engines has timing chain#
Jan 01, 2014 | Audi 2.8 Timing Belt Kit A6
Westinghouse 12cfu, twin cylinder air comp. >20years old. Ex service stn. Shed just rewired 3ph. Is rotation critical? No markings to be found.
rotation is critical as the big end bearings of the compressor are splash fed and the oil in the sump is picked up with a tube and forced into the bearings for lubrication. Second point the pulley spokes are angled so as to produce an air flow around the heads and cylinder to help with the cooling. Rotation arrow is normally cast into the compressor housing bearing support plate behind the pulley
Aug 31, 2013 | Air Tools & Compressors
Freezer not blowing cold air in Westinghouse RJ422V-R fridge freezer
If the compressor is working, then you will need to have it charged.
Nov 22, 2012 | Refrigerators
1988 3yc tarago with carby will not idle once warmed up
You can have numberous problems .. vaccum leaks,idle curcuit plugged,choke sticking . That is a very complicated carborator. You need to have some one with experiance on that stlye carb .
Aug 05, 2012 | Toyota LiteAce Cars & Trucks
I have a very old Westinghouse Air Brake 1BYC, Type Y, maybe model # 209878, air compressor. It is very slow to even pump 80 psi and then the pressure will leak completely to zero. I think wear of the...
If there is no external leakage, then air is probably slipping back past the valves. If the cylinders and rings are good, a valve change may fix it. There are still aftermarket parts available for these machines. As a rule of thumb, a rebuild with rings, gaskets, valves, and bearings usually runs about $100 per horsepower.
Apr 09, 2011 | Air Tools & Compressors
Howdy, I just acquired an air compressor, ''Westinghouse Air Brake Co., Type Y 3YC, SN 136848. I am wondering about parts motor config, cfm output, psi, etc. It appears to be a 2 stage & I'm thinking...
Sep 12, 2009 | Air Tools & Compressors
1954 Westinghouse refrigerator, runs but doesnt get cold.
Hi Conor
What is the model of the refregerator you have ? The model should be on a metal plate on the back ? There are several things to check.
Jun 04, 2009 | Westinghouse Refrigerators
Water drips into refregerator (not the freezer portion)
we have just had our seals replaced and the tech guy that did it also blew the drainage pipes out with compressed air [ a mini air compressor would work ] and now our fridge doesnt leak and gets really cold , the drainage pipe on our westinghouse was at the rear inside near the light
May 25, 2009 | Whirlpool Refrigerator Inverter Box -...
Westinghouse lost it's cool
Yes it can be recharge and you need a qualified technician for that problem.
Mar 19, 2008 | Heating & Cooling
Air Tools & Compressors Logo
239 people viewed this question
Top Electric Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Electric Air Tool and Compressor Expert? Answer questions, earn points and help others
