Question about GE Advantium SCA1000H Convection / Microwave Oven
Oven Halogen Lamp
Hi, I would like to know if the oven needs to come off the wall to replace the Halogen lamp that illuminates the interior? Has anyone ever replaced it. If yes, how difficult, should I take it to a service technician? Thanks, Dennis
  • 4 Answers
It's pretty simple to replace the light without having to remove the oven from the wall...as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, fiOven Halogen Lamp - 64ca8cc.jpgt housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Posted on Jan 29, 2008
GE Profile Advantium 120 Microwave/convection oven combo. Model: sca-1000HBB, Manuf. 11/04 Can you tell me how to replace the light bulb inside the mivrowave? Access? Necessary to remove the complete microwave? Thanks, Bobby Van
Posted on Jul 29, 2007
    President:
  • 3,130 Answers
Yes the oven has to come off the wall and if your carefull and tont touch anything BUT the lamp, you should be ok. The Lamp is located inside the outer case easy to get to by taking out the screws around the rear cover close to the edge and screws on the side. good Luck
Posted on Aug 04, 2006
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
How do i replac the interior light on my frigidaire fmv156dc microwave?
We have the service manual and have uploaded it to our site here to help you.
From page 33:
OVEN LAMP and Lamp Socket REMOVAL
1. Disconnect the power supply cord, remove the oven from
the wall and remove the outer case. (Refer to procedure
of "Removal of Oven from Wall" and "Outer
Case removal ".). And proceed as follows.
2. Open the door and block it open.
3. To discharge the high voltage capacitor, wait for 60
seconds.
4. Remove the three (3) screws holding the hood intake duct
R to the oven cavity top plate, the oven cavity front flange
and the fan duct. And remove the hood intake duct R.
5. Turn the lamp socket and release it from the magnetron
duct.
6. Screw the oven lamp off from the lamp socket.
7. Now, the oven lamp is free.
8. Pull the wire leads from the oven lamp socket by pushing
the terminal hole of the oven lamp socket with the small
flat type screw driver.
9. Now, the oven lamp socket is free.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 10, 2011 | Frigidaire FMV156DC Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Microwave interior light
Very easy to replace...at least on my JVM1790. Remove the top vent....the long plastic thing that runs along the top of the MW. Two screws on top of the micro. Behind the charcola filter (if you installed one) is an access area to the bulb. remove one screw and the entire assy comes out. Simply R & R the bulb.
Oct 19, 2008 | GE JVM1790 1000 Watts Convection /...
MC156SJ light out
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
Dec 01, 2007 | Microwave Ovens
LG MP- 1482s INTERNAL LIGHT CHANGE
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 01, 2007 | LG LRM1230W Microwave Oven
Lamp broken
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to line level (mains) voltage, and that posed a real liability threat, so they stopped using them.
You should be able to find replacements lamps by taking the old one to a local home improvemeant center or department store or an applaince parts store.
Nov 21, 2007 | Neff H7871N2GB Convection / Microwave Oven
GE Profile JE1590--light bulb
The type of screw attaching the casing is called a Torx Tamper Proof screw. You need a Torx Tamper Proof Screwdriver to remove the screws. These screws and screwdrivers come in various sizes. I think the size you need is T20H.
Nov 19, 2007 | GE JE1590 Convection / Microwave Oven
GE microwave interior light bulb replacement.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 19, 2007 | GE Advantium SCA1000H Convection /...
GE Advantium SCA 1001HS
Should be able to get to the lamp by removing the grill.
Oct 04, 2007 | GE Advantium SCA1000H Convection /...
GE Advantium SCA1000H Convection / Microwave Oven Logo
478 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
