Kenwood kdc-bt645u
SOURCE: im loose my wires
Here you go:
This is the wiring diagram for most all the kenwood radios for the last few years. Yours included.
If you need more help just ask.
A good rating would be appreciated.
SOURCE: Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
SOURCE: I need a kenwood wiring diagram
I have found your owners manual your can click here or copy and paste the link into your browser.
http://inform3.kenwoodusa.com/manuals%5Ckdcx492.pdf
Hope this helps.
Richard
SOURCE: wiring diagram for a kenwood KDC MP232
Aftermarket cd players are all universal and have the same colors. You need to go to your local car audio store such as walmart, bestbuy, ect and buy a wire harness adapter. Then all the wires are color coordinated to make it easy, just wire colored wires together and plug in. If I have helped please leave positive feedback. Thanks
SOURCE: I was given a Kenwood KDC-1011S. All wires labled
Yellow is for constant 12v. (Power directly from battery) so it maintains preset stations and clock memory. Red is for Key "on" 12v Power (turns on when ignition key is on) Black is for Chasis Ground. What type of vehicle is it going in? I can get you the corresponding vehicle color as well. Post a comment with make/model & year vehicle. Hope this helps.
