Privilege sensation E 20
Error code E20
3 Suggested Answers
SOURCE: Error code 20
Hi, I also got the error code E20 when the filter became totally blocked during the washing cycle (due to a pair of my son's old work jeans!). Once I cleaned out the filter everything worked ok again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there. Regards, John
Posted on Dec 15, 2006
  • 3 Answers
SOURCE: error code e20 displayed on my washer?????
Can u help? Have same problem
Posted on Jul 28, 2008
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
What is error 20 on frididaire gallery washer? Clothes just sitting not moving at all?
2. Failed pump
Apr 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
E20 error code
E20  error is a problem with the focus on the CD reader.
If the error only occurs on one CD then it's most likely a problem with a smudge or scratch on that CD and not the CD player  lens .
Try cleaning the CD thoroughly with iso-propyl alcohol
Nov 06, 2009 | Car Audio & Video
I have a 97 Buick Regal and I get a E20 error message:cd player
It's just an error message. It stands for Error 20. There is no way to fix the problem. It only reads cd's that it wants. But if it does play a cd, then suddenly stops, and says E20 and spits the cd out, it's most likely because the cd player got too hot. My car does that all the time. And it won't play a lot of burned cd's. Hope this helped.
Mar 24, 2009 | 1997 Buick.5 Regal
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Error code 20
Sep 04, 2006 | Zanussi ZJD1219 Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
