Question about iLO LCT32HA36 Television
Can't remove stand
I can not remove the table top stand from the bottom of the TV. please help
  • 903 Answers
There should be a something that you need to push in at the back of the stand that connects to the tele. Someone needs to push it in hard while someone else tilts the tele forward and up or back and up depending on which way the push in part goes. (Presuming this is a flatscreen tv)
Posted on Oct 23, 2008
We just moved and forget how to put the flat screen onto the table top mount??
Most the time they come with a plastic insert. If you put this in you must remove it and you will see the table top insert holes. Set the stand on something flat and have someone help you guide it in [properly then put the screws back in that you had remove to get it off. General rule of thumb is the table top stand will go straight into the bottom of you TV and may be offset to the back side of the television. Good luck finding the screws as this is the most common lost part.
Jun 21, 2011 | Samsung 50 in. Plasma TV
I need to remove the stand from my T260HD monitor
You need a table and a blanket spread on the table to prevent scratching the screen. Lay the set face down on the blanket and there will be usually 4 screws in the middle at the bottom facing up as the set is flat on the blanket that is holding the stand in place. Also sometimes there is a screw at the very bottom going up towards the top of the set.
May 24, 2011 | Samsung T260HD 26 in. LCD TV
How do you remove table top stand from tv
There are 6 screws on back of the TV in line with the column for the stand. Remove these and the stand should slide out of the bottom. Some models may have in addition a plastic tab that locks it in place.
Mar 01, 2011 | Proscan 32LA30Q Television
Need a table top stand for a LG 15" (model
Tries websites like Amazon.com,Ebay.com to buy a new or used base stand for ur tv.
Dec 08, 2010 | LG 15LC1RB 15 in. LCD Television
I cannot remove the stand for my evotel elcd32usb, can you help me please
There are 6 screws in the centre back of the TV, 2 rows of three. There are arrows embossed on the plastic case to identify them.
Remove all 6, then pull the stand off.
Apr 26, 2010 | Televison & Video
Sony bravia pedestal stand is unstable
http://www.docs.sony.com/release/SUWL31_EN_ES_FR.pdf This link will show what it looks like when removing base to wall mount.They always recomend a mounting strap that connects to the rear of the TV and then screws into the table it will be sitting on.Not sure what they expect you to do if you have a glass top table. http://www.docs.sony.com/release/SUWL31_EN_ES_FR.pdf
This is a link to all the downloadable manuals and what not.Well hope this will help,and good luck.
Mar 13, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Sep 07, 2009 | Televison & Video
Lost the table top stand for my KDL-40s4100
I might have one of this table top stand.
Write to jah2mil@hotmail.com for more info.
Jul 08, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
iLO LCT32HA36 Television Logo
178 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
