Zanussi FJS1225W Front Load Washer
Problem for Zanussi FJS1225W Front Load Washer
How do I fit a new door gasket?
By stevec on Aug 04, 2006
I've managed to remove the old door gasket, but I'm having trouble fitting the new one(I cannot fit the sping). Can the seal be fitted with the drum still in the machine?
Same Problem
Mar 27, 2009
-   i got no instructions with the new door seal!!! where does the spring fit onto?? -   Guest
Jan 04, 2008
-   but how do u get the seal on in the first place - finding it impossible to keep on at the top - havnt got to the spring bt yet, tried fairy on this bit also? theres obviously a knack to this which i just dont have cheers-   barry_1176
Best Solution
posted on Sep 15, 2007
Very Helpful)
sarek
Rank: Apprentice
Rating: 100%, 2 votes
after putting the seal on with the aid of washing up liquid put the spring on first by the door catch hold it on with one hand and isnert a screwdriver in the hole for the door catch this will enable you to hold the spring on if you put your knee against the screwdriver giving you two hands free to push the spring on
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 28, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It was really helpful to use washing up liquid both to fit the rubber bellow over the inner drum and to fit the spring ring to fix the bellow. The key is the washing up liquid. Thanks for your help.
Solution #3
posted on Feb 14, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Solution #4
posted on Aug 31, 2006
Helpful)
WASHDOCTOR
Rank: Guru
Rating: 87%, 244 votes
WELL TO BE ONEST WITH YA YOUR GONNA STRUGGLE WITH IT TO GET IT ON AS THE FRONT PANEL DOES NOT COME OFF THE MACHINE UNLIKE THE HOTPOINTS. wHAT YOU HAVE TO DO IS FRIST PUT THE DOORSEAL ON WITH OUT THE SPRING RING. THEN GET SOME FAIRY LIQUIED AND RUB IT INTO THE SPRING RING THIS WILL HELP MAKE PUTTING IT ON A LITTLE EASIER. YOU MIGHT MOST LIKELY WILL NEED TWO PEOPLE FOR THE JOB TO HOLD THE ONE SIDE OF THE SPRING AS YOU FOR IT ON TO THE OTHER SIDE. TURST ME FAIRY LIQUID WILL MAKE THE JOB ALOT EAISER. AND YES IT IS ALWAYS FITTED WITH THE DRUM INSIDE THE MACHINE AN AVERAGE TIME FOR AN ENGINEER IS ABUT 45 SECONDS FOR GETTING IT ON THE DRUM. TRY TRY AND TRY AGAIN MY FIRST ONE TOOK ME 20 MINS I STRUGGLED BUT NOW I DO EM IN A FLASH. FAIRY IS THE KEY IT HELPS THE SPRING TRAVEL EAISER INTO ITS POSTION.
Was this helpful?
Yes
No
Solution #5
posted on Aug 18, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Zanussi 1250. WJS 1397W. TurboDry. Jetsystem Excel. RSI, Rinse Sensor Injection These pages are about how to fit the door seal on a Zanussi 1250. WJS 1397W. TurboDry
http://www.agreatportal.com/zanussi_1250/index.html
Hope this helps you out :)
Popular Solutions for Zanussi FJS1225W Front Load
Questions and Unsolved Problems for Zanussi FJS1225W Front Load
Do you recommend Zanussi FJS1225W Front Load Washer?
Answer
Answer
Hiya my grandfather think the problem is the motor, but it does not spin. it turns on, drains the... (More)
Answer
zanussi fls 1383w program cycle keeps clicking round and stops on A sometimes it works but mostly it... (More)
Answer
zanussi jetsystem 1200xc fj1254w - door interlock came on as soon as door was closed. will allow... (More)
Answer
The LED display disappears and the cycle stops. I have to press the green start/pause button to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machines Experts
Top Washer & Dryer Repairmen
in , CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
