Question about Whirlpool Duet GHW9150P Front Load Washer
Model # wfw9400sw00. Whirlpool front load washer
Blew mother board. All other boards blown. Was there a recall?
CMV9
  • 594 Answers
SOURCE: Whirlpool Cabrio Washer Error message code F1
The following list of codes indicates a possible electronics communication problem with the washer:
Cabrio washer - F1, F2, F40, F41, F42, F50, F51, F52, F53, F54, F72
To remove the error display, press Pause/Cancel twice.
PLACEHOLDER FOR ART
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Please do not forget to rate and comment about your experience with fixya today.
Posted on Aug 17, 2008
SOURCE: Rotting Smell from Whirlpool Duet Front Loading Washer
Take the panel off of the front of your washer below the door and in the middle there is a round removable plastic door like piece. Take it out and clean out all of the junk in behind it. You might find loose change, nails and a variety of other thnigs that have become stuck in there besides mold. This will help with the smell and also the water that sometimes remains in your washer after the cycle is over. You need to do this once/twice year.
Posted on Oct 14, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Posted on May 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: model: wfw9500tw01 f35 error
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Where can I get a mother board for a Freejet 3in1 cordless hoover model FJ180WB2
probably need too replace the whole board. safest way in case board is at fault. Appliancepartspro.com with model no.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
May 02, 2016 | Hoover Vacuums
My LG front load washer will not drain the water or spin out the water and it always has a series of beeps and then the error code IE which says in the manual that there is an inadequate water supply, i...
My daughters machine, a whirpool, did the same thing. A repair man came out and he told her to call back and complain about the machine....there was a recall on the machine because of a mother board problem in the computer. She called back and talked to Whirlpool and a service man came out and fixed it for free.
Jul 16, 2011 | LG WM-2277HW Front Load Washer
Washer stops mid cycle with a F1 reading on display
control board failure some models have been recalled call whirlpool and have them check your model
Oct 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool wont power up
Check to see if there is any blown fuses, Check if power is going to the CCU board, if not you need to replace board. Check harness connection, unplug washer for 30 mins, and try again
Good luck
Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Same issue with drainage of water
CHECK ALL THE FUSES ON THE MOTHER BOARD FOR THE WASHER,YOU MIGHT HAVE A BLOWN FUSE OR A BLOWN RESISTOR ON THE BOARD ,AND YOU WOULD HAVE TO CALL A REPAIR MAN TO FIX THAT BOARD OR CHANGE IT OUT.
Aug 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Runs intermittent faults F-70
The Duet washer is a good machine, just unfortunate Whirlpool engineers used oxidative circuit board coatings. All the circuit board connections are oxidizing causing the machines to have faulty connections. We have fixed the problem using this information.
UNPLUG the machine first . Take the top off (3 screws in the back) , remove the mother board box from the frame housing and remove the lid. Now you can see the circuit board.
Carefully remove ONLY one (clip plug-in) at a time. Scrap with a (knife or sandpaper or steel wool ) the edge connector where that plug was, on the circuit board removing the oxidated metal (it may not look oxidated but must be cleaned), Next put ( vaseline or mineral oil) on the edge connector where that plug was, NOTE: Vaseline or mineral oil is a non-conductive oil and will not effect electronic operation but will prevent further oxidation and the erratic operation of the mother board will cease.
Now do the next plug and repeat until completed.
NOTE: We recommend only one plug at a time so you do not get confused where each plug belongs.
Put the cover back on the mother board box and reattach to the frame, then put the lid back on and screw it down. End of any problems.
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error Code F22
loose connection or mother board again
Jun 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leak samsung front load washer
Hiya bcd1...what model number? see below info.. is yours one of these?
The front loading washing machines have been known to leak water onto the electrical connections to the machine's thermal sensor, which could cause an electrical short and ignite a circuit board, causing a fire.
The recall covers 250,000 Maytag washers and 20,000 Samsung front loaders.
Maytag machines affected have model numbers beginning with MAH9700 or MAH8700. The Samsung washers have model numbers beginning WF306BHW and WF316, although not all serial numbers are subject to the recall.
learn more detailed information about the recall by visiting Whirlpool...or Samsung's at www.samsung.com/washerrecall.
Hope you find useful!
Regards Faggly
Mar 19, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
