Question about Sewing Machines
Pfaff 230 Automatic Dial a Stitch Manual needed
5 Suggested Answers
sew helpful
SOURCE: I can't get my Pfaff 230a to straight stitch!
The stitch selector switch is most likely the culprit. Have you tried operating the machine upside down?
Posted on Jan 17, 2010
  • 1116 Answers
SOURCE: Help with sewing machine manuals for Pfaff 230, Singer 95-10
Sewusa.com has the Pfaff manual, but could not find anything for the Singer 95-10. They have a 95-40 and tias.com has a manual for the 95 series.
Posted on Mar 20, 2010
Testimonial: "Thank you very much for the info, big help"
  • 255 Answers
SOURCE: Hi, I've recently acquired a Pfaff 230 s#5 150 268, need parts
HI. Sew4Less.com (http://www.sew4less.com/index.php) has parts for your Phaff 230, including belts, a bobbin case, and both service and repair manuals.
SewingManuals.com (http://www.sewingmanuals.com/index.htm) has both the user and service manuals.
Hope this helps!
Happy Sewing!
Robbie
Posted on Mar 25, 2010
  • 1456 Answers
SOURCE: I have pfaff machine model
Hello
It's just a fact that any machine that only does a straight stitch has a better straight stitch than any machine that will also zig zag. The more things they do, the less perfectly they'll do each one in most cases. A plain zig zag will have a better straight stitch than a machine that also does reverse-cycle stitches. The thing is that the more play they have to build into the needle area, the harder it is to keep it from moving slightly this way and that way when you don't want it to, like on a straight stitch.
You may also be having a combined problem when you're sewing very thick seams. If your entire presser foot is not perfectly flat on your item, it will not sew as well as if it were. This is even worse when you get to a junction of several seams, and your presser foot may be at an odd angle to get up and over the junction. You can use a Hump Jumper to help, or even a folded piece of something, but it's still not going to be as perfect as if you were on a completely flat surface. You can use a Sewing Hammer to pound things as flat as possible before stitching, which will help some. You may also get help with a different type of foot although it doesn't really sound like that's your problem.
If you have a control box, push the buttons so all the lights go off. Something is making the machine back-tack. I have seen the problem be a mechanical issue. In that case you would be better off taking it to the shop.
Posted on Jul 12, 2011
Blanket stitch on Pfaff 1171
You need to check your owner's manual. Most machines of similar age do not have the blanket stitch.
Looking at Pfaff 1229 sewing discussion topic PatternReview com
(see comment)
Pfaff 1171 Tiptronic Sewing Machine
Aug 09, 2017 | PfaFF Sewing Machines
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Feb 19, 2017 | Sewing Machines
Pfaff Passport 2 How do I get zigzag stitch to work?
The manual instruction begins on page 21. Have you looked there how to select a stitch and how to adjust the width?
http://new.pfaff.com/SiteMedia/PFAFF/Products/Machines/passport-line/passport2_0/Manual/passport_2_0-manual-EN.pdf
Aug 26, 2014 | Sewing Machines
1222 Pfaff can not adjust to a large stitch
Will need more info to help you. Is the white dot on the zig-zag dial still at the top? If not you will NEED (no way around it) a zig-zag dial rebluild. Most pfaff repair shops do not know how to do this repair, will need to find a 1222 expert.
This is my gess with what you have told me.
Hope this helps
Mar 31, 2011 | Sewing Machines
Mar 20, 2010 | Sewing Machines
Pfaff 360 automatic slows and stops after only minutes of use
Pfaff 360's don't like to sit, they like to drink. . .. oil.
Set top knob "C" to 0
Right top (zig-zag knob) set to 4, lever below but on the same dial points straight down. Set stitch length to 4. Run 5 minutes medium speed.
After that lift off the top cover and spray inside with "Tri-flow", then run a hairdryer on it for 20 minutes to warm up or set near a warm lamp overnight. Run daily 5-10 minutes and exercise the right knob between 0 and 4 (zig-zag). It should come back to working with oil, time, and heat.
Apr 13, 2009 | PfaFF Creative 7570
PFAFF 362 Sewing Machine: The shift lever to move from straight stitch to zigzag stitch is stuck in zigzag mode and will not release to go back into the straight stitch. The machine sat unused for a...
Remove the top cover (grasp and lift straight up), spray with "Tri-Flow, liberally inside. Pay attention to the right 1/2 and behind the front dials.
In Front, each dial has a small square opening on the side, use the tube included with the "Tri-flow" to squirt lube inside them. DO NOT use WD-40.
Run the machine daily for 5-10 minutes (set the dial "C" [top front that goes up to 8] to 0 also set the dial on top of the case to 0. Move the Zig-Zag lever (upper right) from 0 to 4 and back again. Respray with Tri-flow. After a couple of days, if it is still stuck place a hair-dryer or light nearby to warm it up to skin temp.
Between the temp and the oil, it should begin working.
Break a Leg!
Sep 25, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
117 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
