Question about HP DesignJet 1050c plus InkJet Printer
HP 1050C IP address
How do I change the IP address on the NIC card ?
  • 10406 Answers
SOURCE: How do I change the IP address on my networked HP
Follow the instructions on the manufacturer's web-site:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=ca&taskId=115&prodSeriesId=3656598&prodTypeId=18972&prodSeriesId=3656598&objectID=c00868762
to change the IP-address.
Or, call the MIT Information & Computing Systems Computer Help Desk.
Posted on Dec 14, 2009
  • 1126 Answers
SOURCE: When attempting to change the ip address on hp
Somewher in the menu you need to deselect dynamic or DHCP and select STATIC for IP type...then it will allow you to set the IP address.
Posted on Dec 28, 2009
  • 137 Answers
SOURCE: How can I print out a typical configuration page
Hit the menu button, go to reports. Then print out the system settings or network configuration report.
Posted on Jan 21, 2010
SOURCE: URL or IP Address changes every 7 to 10 days
very easy, config never release for the (ip of the printer in your router), thats all, this is even better that fixed ip.
Posted on Jul 02, 2010
  • 4 Answers
SOURCE: We have an Hp Laserjet
try doing the nvram init. should solve the issue.
Posted on May 02, 2011
IP address change needed on a AlphaServer DS10
First, identify the NIC you wish to change; use:
$ MC LANCP <ret>
> SHOW DEVICE
Next, use the menu driven utility "TCPIP$CONFIG", to set your desired IP address etc:
$ @TCPIP$CONFIG <ret>
Option 1 - core environment
Option 2 - Interfaces (then select your NIC or the IP Addr to change)
Option 2 - add/change a Primary address on *** (where *** is your NIC).
May 15, 2012 | Compaq AlphaServer DS10
Tip
How to Check TCP/IP Configuraitons
The first step in the troubleshooting process is to check the TCP/IP settings. You can check it by using the IPCONFIG/All command on the command prompt. You will see the configuration results. If you see a blank configuration for a card this means then the card is not assigned any IP address. You can assign the IP address manually or via DHCP server. If you are using the DHCP server for assigning the IP addresses then you can use the following commands to get and release the IP address.
IPConfig/Release
IPConfig/Renew
IPConfig/All
If the computer is still unable to obtain an IP address, then there are several things that can causing this problem such as bad network cable or NIC card, DHCP server might have assigned all the IP addresses from its pool, mis-configured TCP/IP settings, incorrect user name and password. You can try to add a new well configured machine to the replace the malfunctioning machine to see if the new machine is working with its settings. Also see if the driver of the NIC is properly installed or not. In case of driver's problem go to the vendor's website and install a new exact driver for the NIC.
on Mar 25, 2010 | Computers & Internet
I have Dlink DP-300U print server which has ip address of 192.168.2.150 but i want to change into 10.xxx.xx.xxx ip range how can do? i tried by changing the ip address of the pc to Dlink switch range but...
Ideally, you change your PC's NIC to an IP in the range of 192.168.2.150, say 192.168.2.2 with mask 255.255.255.0 then directly connect your NIC to the Print Server and open your browser to 192.168.2.150, from there change the IP address of the Print Server.
Jun 25, 2011 | D-Link DP 300U (DP-300U) Print Server
Network key for ot 800
How do I configure my NIC with a static IP for use with a SpeedTouch Home?If you are using an Alcatel SpeedTouch Home (without a router), a PPPoE client such as NTS, WinPoet, or RASPPPoE, and are experiencing stalls and freezes while surfing or connected, it may be that your NIC is not configured correctly. You must set a Static IP on your NIC. If you have it incorrectly set for "Obtain IP automatically" it will be looking for a DHCP server that does not exist. During the time the NIC is searching for the DHCP server you will experience stalls and freezes. An incorrect NIC settings will also cause the PC to take a longer time to boot up.
This FAQ has two sections:
Section 1 - NIC Properties for Windows95/98/ME
Section 2 - NIC Properties for Windows2000/XP
bred.gifStep 1
Click on Start ->Settings ->Control Panel ->Network
bred.gifStep 2
Once at the Network Window scroll down and look for the first entry in the box marked Internet Protocol (TCP/IP) that is associated with your hardware ethernet card (ignore dialup, AOL, and VPN type bindings). Select the correct Internet Protocol (TCP/IP) entry and click PROPERTIES.
Actual screen shots may vary
bred.gifStep 3
Select the IP ADDRESS tab. Select Use the following IP address and enter 10.0.0.1 and 255.255.255.0 into IP address and subnet mask fields respectively. Do not click on OK yet.
bred.gifStep 4
Select the GATEWAY tab. Enter 10.0.0.138 into New Gateway field and click on Add. Click OK.
bred.gifStep 5
Close all windows and restart the PC.
Section 2 - NIC Properties for Winows2000/XP
bred.gifStep 1
Click on START -> SETTINGS -> CONTROL PANEL -> NETWORK CONNECTIONS. Right click on Local Area Connection and select Properties
bred.gifStep 2
On the General tab highlight Internet Protocol (TCP/IP) and click PROPERTIES.
bred.gifStep 3
Select the GENERAL tab. Select Use the following IP address and enter 10.0.0.1, 255.255.255.0, and 10.0.0.138 into IP address, Subnet mask, and Default gateway fields respectively. Click OK.
bred.gifStep 4
Nov 11, 2010 | Alcatel Speed Touch Home Modem
Kyocera 3035 will not print - NIC card red LED flashing
First turn the main Power Switch off, then unplug the network cable from the nic card and leave it unplugged. Then turn the machine back on, when it says ready to copy, press the printer button and print out a network status page. Then hook the network cable back up and go to a pc and click on start then control panel and look for printers and faxes and click on it, then right click on the Kyocera Printer Icon, then click on properties in the drop down then click on the port tab, then click on configure port and check the ip address and make sure it matches the one on the network status page, if it doesn't put in the correct IP Address and apply the change. But if the ip address is right just try printing again. If it prints ok then you are done but if it doesn't try this click on start then run and then type in cmd, then on the screen that opens up type in ping, then a space, then ip address of the Kyocera Machine then press enter, if the Nic card is connecting to the network you should get a reply from the Kyocera's Nic Card if you do then the Nic Card is ok and the Kyocera print driver may have to be deleted and then re-installed. Hope this helps.
Aug 06, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Just installed a D-Link DFE 530TX network adadpter into Dell Dimension 5000 desk top. Runnng Windows XP SP3. BT Home Hub 2.0 router. Even though broadband connection is fine to the router. The network...
Sounds like an IP address problem. Your IP address on both the NIC card (DFE 530) and the router have to be in the same address range. You can do this 2 ways. 1... Have your router hand out addresses automatically. Make sure DHCP is enabled and that you have at least one address available for it to give out. ie. 192.168.0.2 through 192.168.0.3. The first three number must be the same as the router. The other option is to manually set your IP address on your nic card to match the router. If the router is lets say 192.168.0.1 then you can assign 192.23.34.2 to your computer NIC. If you haven't been able to access your router then check your router manual to find out the default IP address and use the same number for your NIC changing only the last number. The largest number you can use is 255. Hope this helps.
Jul 12, 2009 | D-Link DFE-530TX+ Fast Ethernet PCI...
Vista ultimate 32 not connecting to wireless
169.254.x.x IP suggests that your NIC is not communicating with the DHCP server of your Router. Try disabling/enabling the NIC card and in the TCP/IP properties, make sure that the IP address is configured as "Bobtain IP address automatically"
Also try installing the latest drivers for your NIC card.
May 13, 2009 | Trendware TRENDnet 4-port Switch - 54 Mbps...
Problem with Fast Ethernet NIC and Broadcom WLAN adapter
you need to dissable dhcp in the router and manually assign ip address as dhcp automatically changes your pc's ip address, for example if your router ip address is 192.168.0.1, then you go online with your notebook first it will get 192.168.0.2, then the next pc online will get 192.168.0.3, if you go online with the pc first it will get the 192.168.0.2 instead
Aug 29, 2008 | HP Pavilion dv1000 Notebook
1050C plotter
replace the network card, then reconfigure the IP address in the machine and that should take care of you. if not then you could have a bad emod (electronics module). also check the cat5 cable and the network drop for functionality.
Oct 11, 2007 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
311 people viewed this question
Seeker5211
Seeker5211
