Question about Sport & Outdoor - Others
How to replace lift system on 1997 Dutchman pop up camper model 1004
Replacing all cables and springs
  • 68 Answers
SOURCE: Broken cables to lift roof
http://www.customcylindersintinc.com/camper_trailer_roof_lift_system.htm
This should help, Pictorial and instructions. Also parts available.
Thanks for using Fixya
Jerry
Posted on Mar 26, 2009
  • 13433 Answers
SOURCE: how to tighten cable on pop up camper
the adjustment can be done by your dealer, contact them see how much it costs.
Posted on Oct 26, 2008
  • 68 Answers
SOURCE: replace left spring in pop up camper
Search this site and you will find what you are looking for.
Jerry
savindude
  • 175 Answers
SOURCE: I need a repair/owner's manual for 1999 Coleman
Tried googling Coleman? They might be able to help.
Posted on Jul 02, 2009
Ironfist109
  • 3018 Answers
SOURCE: I have a 1993 Coleman
You will have to contact them to get the information you requested. Their contact info is listed below.
Coleman Trailers - manufactured by Fleetwood Enterprises, Inc. - Before 2006 - Toll free: 1-800-544-8193
Customer Service Email:warranty@dutchmen.com Website: www.coleman-rv.com
Regards, Tony
Posted on Apr 08, 2011
I need to replace my 8345 converter in my 97 dutchman camper
go see a camper sales and service center . LOCALLY
Oct 13, 2017 | Cars & Trucks
Owners manual for 1997 flagstaf popup camper
You will have to contact Flagstaff, but you also need the actual model number of your camper. You can also google a manual for a 97 Flagstaff model # _______
Sep 13, 2014 | RVs
I bought a pop up. On the way home from buying it popped off hitch (apparently the coupler needs to be replaced)- how do I go about repairing (or does anyone know of a place in southe east WI area that...
Hitch: Verify the obvious. 1-7/8" or 2" ball and coupler. Some couplers can be and may need to be adjusted. Look for a screw on the rear side.
Sorry, not much help on the lift system. Although, I rigged a winch up to my coleman instead of replacing the whiffle tree. You may be able to do similar.
Apr 09, 2010 | Coleman Campers Grill
Jayco lift system cable replacement
Try this link and see if it will help you any with the info that you need. Sure hope this helps you find resolution to the problem. Best wishes.
http://www.ehow.com/how_4708883_repair-jayco-camper-cables.html
Jul 23, 2009 | Sport & Outdoor - Others
How do I replace my broken cabel in my '94 Skamper pop up camper?
How do I replace my broken cabel or coil in my '94 Skamper pop up camper. The cabel is bent on the right rear corner, It is twested and bent and I have tried to repair it but keeps getting twested and re-bent. My question is if I can't replace it or repair it can I cut it off andraise three corners and left the right corner and prop it up with a bar support.
Jul 17, 2009 | Sport & Outdoor - Others
Jun 29, 2009 | Sport & Outdoor - Others
Broken cable in older Coleman pop-up camper...how to replace it? Can't see in body of camper where the cable needs to go through to the posts that raise the top.
This camper uses the Coleman lift system which uses a threaded rod that connects to a tracked distribution block to which all four cables are connected and then routed by pulleys to all four corners of the popup.First raise the popup to it;s full height by using automotive jacks and poles once extended securely clamp the poles to the telescoping up rights This IS SUPER IMPORTANT FOR YOUR SAFETY. Next get under the camper find the broken cable unbolt it's routing pulley(s) pass the broken ends out the pulley(s).Next unbolt the end from the distribution block. followed but unbolting the cable from in side the telescoping column;carefully note the routing in side the column. Buy or make up an exact length cable of aircraft grade stainless steel twisted wire cable of the same gauge. Reverse steps to re install,take lowering strain on crank make sure crank handle is captured by anti free wheeling device on camper un clamp poles remove, lower and raise top by crank to ensure smooth working. You're finished.
Apr 19, 2009 | Coleman Sport & Outdoor - Others
Jerry
Mar 24, 2009 | Sport & Outdoor - Others
Replace left spring in pop up camper
Jerry
Mar 20, 2009 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
519 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
