Question about Gateway DC-T50 Digital Camera
Memory card I love my Gateway DC-T50 but the card fills up too quickly.I have a Kodak SD 256 MB memory card and want to get a bigger one.So I went and got a 2 GB and installed it , the camera screen said This card cannot be used. I took it back to the store and the clerk said it was probably too big because I have an older camera. So I exchanged it for a 1GB and it shows the same error message. My question is; what is the biggest memory card this camera can use? I have misplaced my manual, or I would look it up there. Thanks in advance.
  • 76 Answers
Try a 512mb because your camera could be older then the 1 and 2gb memory cards can handle...or depending on where you are..you could take it to Best buy and they could tell you...hope it helped =)
Posted on Oct 23, 2008
Who can repair a Gateway DC-T50
Refer to the manual page below - note the last 2 items
If you take the camera and the card to a sales outlet the assistants are usually helpful
Inserting an SD Memory Card(Optional)
All images and video clips taken by the camera can be stored in an SD (Secure
Digital) Memory Card. Even if the camera's power is OFF, the images saved in the
SD Memory Card are not erased. An SD Memory Card can be repeatedly read and
written. You may also expand the memory capacity up to 512MB so that you can
store additional images and video clips.
1. Make sure the camera is off.
2. Slide the battery/SD Memory Card cover in the direction of the [OPEN] arrow.
3. Insert an SD Memory Card :
The front side of the memory card (printed
arrow) should face towards the front side
of the camera.
If the card cannot be inserted, check the
orientation.
4. Close the battery/SD Memory Card cover.
To remove the SD Memory Card, make sure
the camera is off. Open the battery/SD Memory Card card cover. Press
lightly on the edge of the memory card and it will eject.
Note:
If the camera is powered-on without the card, the "NO CARD" message appears on
the LCD monitor.
To prevent valuable data from being accidentally
erased from an SD Memory Card you can slide the
write-protected tab (on the side of the SD Memory
Card) to "LOCK".
To save, edit or erase data on an SD Memory Card,
you must unlock the card.
MultiMedia Card (MMC) can not be used.
You need to format an SD Memory Card before using it in this camera
Feb 19, 2015 | Gateway DC-T50 Digital Camera
Gateway digital camera DC-T50 5.25 megapixels put new memory card and a card error message appears
The camera uses SD cards. I assume your new card is 8GB, not 8MB as you stated. If this is the case, it's an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the SD-only camera. You need to use SD cards, 2GB and smaller.
You may download a copy of the manual here.
Apr 04, 2012 | Gateway DC-T50 Digital Camera
HI I NEED TO KNOW WHAT TYPE OF MEMORY CARD SHOULD I USE FOR THE DC-T50 THANKS
Hi, The DC-T50 only takes regular SD cards up to 512 MB in space. Most cards that are sold now are SDHC, which are NOT compatible. If you can find a 512MB SD card, it should be extremely cheap.
Happy Shooting!
Mar 05, 2011 | Gateway DC-T50 Digital Camera
What size memory card does the kodak easyshare cx6200 take?
The internal memory for this camera is 8 MB.
The manual indicates using memory cards of size 8 to 128 MB, so this is an early SD memory camera, following the original SD standard. Do not try SDHC or SDXC cards. The camera will support a 1 GB card. It *might* support a 2 or 4 GB card, but since this is a 2 Mpixel camera, a 512 MB or 1 GB card will allow you to save thousands of jpeg format pictures.
Mar 01, 2011 | Kodak EasyShare CX6200 Digital Camera
Bought new SD card for my Gateway DC-T50 but when i turn it on give me card error
bought new sd card for gateway dc-t50 camera. camera dept said camera is too old for the sd cars.
Jan 16, 2011 | Gateway DC-T50 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Where can I get a memorty card SD 128 MB for my Kodak Easy Share C 743? Can I also use a larger memory card such as 2 GB or 4 Mb? A. N. sparklersconc@yahoo.com
You can use SD cards up to 2GB in size. You cannot use SDHC cards bigger than 2GB. You should be able to get SD cards at any office supply or electronics store. You could probably even find them in most supermarkets and drug stores, though they might cost a little more.
Mar 08, 2010 | Kodak EasyShare C743 Digital Camera
What kind of memory SD card would work for Panasonic DVD Recorder DMR-ES46V? I was hoping to put in a 8 gig memory card but those are all SDHC. Will those cards work in this unit?
This info is straight from the panasonic website. The owners manual and more info for the unit can be found here.
Hope his helps!
Suitable SD Memory Cards
8 MB, 16 MB, 32 MB, 64 MB, 128 MB,
256 MB, 512 MB, 1 GB, 2 GB (Maximum)
Mar 16, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
SD card error
Dec 05, 2007 | Samsung Digimax 4010 Digital Camera
Gateway DC-T50 Digital Camera Logo
158 people viewed this question
Top Gateway Cameras Experts
mohamed salim shaikh
Steve
Are you a Gateway Camera Expert? Answer questions, earn points and help others
