Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My computer will not recognize My Digital notebook and it is making a clicking sound and the light will come on
Replace with new one, they are ****
Posted on Oct 25, 2008
How do I download fromk my camera to my computer pictures that I have already downloaded and deleted from computer? They are still in camera.
Attach the camera and make sure the computer recognizes the camera if ti does not open a program to download them see below if it prompts you to make a choice as to what to do click open folder and copy and paste them into the computer.
If it does not but does recognize the camera go to My computer or just computer where you can see the drives like C: and DVD drives look for the camera drive if you don't see it just click other drives until it opens the camera if it does not then its not recognizing it. If it opens click through each folder in it until you find the pictures copy them and paste them to your pictures folder on your computer.
Oct 22, 2011 | Canon PowerShot A590 IS Digital Camera
Light blinks on my portable WD elements 500 but the computer dosent recognize it. Im using a Powerbook g4 power pc. I have info in it i need to reach & other computers recognize the HD but not my...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 14, 2011 | Western Digital 500GB ELEMENTS 500 GB USB...
Dropped it from a few inches. Computer wont recognize it. Tried hooking to my laptop, it loaded the drivers but still wont show up in My Computer.
try taking it apart making sure that the connections are plugged in
good and tight , also reboot the computer while its plugged in , if
still nothing listen for a spin up and spin down sound or a clicking
sound , the spinning up and down sound means the motor is
malfunctioning , a clicking sound means the units heads are
malfunctioning , if any of these problems exist let me know
my name is David or user name terminalcon just add attention
to; and I will help you further .
Jan 28, 2010 | Western Digital Elements powered by WD 320...
Not recognized Toshiba notebook running Vista.
It is very possible it is a driver issue. What version of vista is this? 32bit or 64bit. You can right click on my computer and click properties. Remove drivers already installed and reinstall them from manufacturers web site. Make sure you keyboard is compatible with vista version you are using. If it is 64bit lots of components are not compatible. Good luck.
Jan 03, 2010 | GrandTec GlowType GLW-1000 (GLW1000)...
Drive light is on and makes clicks
Regretfully, Western Digital drives have been known to fail and the sign is a fail to recognize, and the infamous clicking.
I've not found any solution other than attempt data recovery with Disk Warrior or something similar..
There are data recovery companies but they aren't cheap...
Jun 08, 2009 | Western Digital 250GB MyBook External USB...
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
My computer not recognized the USB Flash memory, but it recognized other device like the mouse, webcam scanner, digital camera ... Thanks for your help
if usb flash memory is working on other computer/laptop then do the following step.
Insert the usb flash memory.
Goto desktop, right-click my Computer, click Properties, click on Harware tab, click Device Manager button.
There should be yellow exclamation(!) sign showing Unknown Device
Right-click and select UnInstall.
Reboot your laptop
It should work.
May 30, 2009 | Dell Inspiron 6400 Notebook
Usb port
Have you installed the driver for your digi cam? usually you need to install a driver for it to work on your system.
check your digi cam's manufacturers website for downloadable drivers and install it in your laptop.
hope this helps, please rate.
Feb 07, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Computer won't recognize ipod nano (fatty)
hi :) well, maybe your nano needs to get updated to your computer. and the last part of your question, it always makes two sounds when you connect any ipod to a computer :) hope this helps :)
Nov 21, 2008 | Apple iPod nano 3rd Generation
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
