Question about AEG L86800 Front Load Washer
Errorcode C3 When connected to power (even if machine is switched off) the machine make a "buzzer" noice. The waterpump running all the time. In the third display errorcode C3 is prompted. It occured after changing to a new motor. The machine has been unused for a couple of years after the motor failure. The machine is bought in Sweden and its sold as "AEG Lavamat 86800 Update". Thanks in advance!
  • 3,230 Answers
This error code means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
hope this helps.
Good Day......
Posted on May 06, 2009
Your merchine as over filled with water take back off and clear out water
Posted on Mar 22, 2007
Miele 1203 washer failed during a cycle and buzzer on no fault lights
check all the wirings connectuions! and maybe you have dirty rottary switch! you can clean the switch!
Oct 01, 2007 | Washing Machines
2 lights. 2 switches and a buzzer. how to connect them to make the buzzer sound when a light is turned on
Copy following links:
http://waterheatertimer.org/images/3-way-circuit-with-buzzer-300.jpg
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Above illustration assumes that buzzer is rated for 120Volts.
If doorbell buzzer is rated for 12-24 Vac, then copy following links:
http://waterheatertimer.org/images/3-way-circuit-with-buzzer2-300.jpg
You need contactor with 120Volt coil. The light switches turn on light. At that moment, power goes to 12-24V doorbell transformer from hardware store. At same moment, power goes to magnetic coil on contactor. The contactor is a switch, and it connects wires between transformer and the doorbell buzzer. Buzzer turns ON.
When light turns off, buzzer turns off.
http://waterheatertimer.org/H230A.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 17, 2013 | Electrical Supplies
Can I make a water activated switch for a water detector alarm
Yes this is possible to do. If you have a radio shack near you the parts are not much to get. First you will need to get a water sensor. Next a pizo buzzer and a power transformer that matches the power input of the buzzer. You take one side of the wire from the transformer and cut it in half. Connect one of the cut wires to the common screw terminal on the water sensor. The other cut wire and connect to the normally open screw trminal. PLUG THE TRANSFORMER into the ac outlet. Push the sensor switch to see if the pizo sounds. then put back in orignal spot.
Apr 09, 2013 | Washing Machines
FEQ1442ES1 works but no heat
Instructions
1Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
2Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
Jan 09, 2013 | Dryers
How can I disconnect the alarm when the drying is finished?
  • Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
  • 2
  • 3
    Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
  • 4
    Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
  • Feb 17, 2011 | Miele Novotronic T230C Electric Dryer
    The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
    Flashing (approx. once every second): Out of paper
    Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
    Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
    If
    Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
    switch
    Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
    Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
    Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
    Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
    Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
    the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
    Finally
    Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
    backup data in the input buffer will be cleared according to the flowchart on the next page.
    To clear the input buffer, turn on the power while pressing the SEL switch.
    The following messages will be printed.
    "Clear Data in Buffer"
    "Cleared Data in Buffer"
    To print the data in the input buffer, simply turn the power on.
    The following message is printed and the data in the input buffer is printed.
    "Power Down(Data in Buffer)
    Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
    Turning the beep off?
    1Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down. Step2Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device. Step3Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels. Step4Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Jan 11, 2009 | GE Profile DPXH46EA Electric Dryer
    Miele w1203 fault
    use the small orange tab to tighten down on the light just inside on the top of the door. i had the same symptoms and it fixed them right away.
    Oct 03, 2007 | Washing Machines
    AEG L86800 Front Load Washer Logo
    1,099 people viewed this question
    Top AEG Washing Machines Experts
    shaun taylor
    mikenearman
    Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
