Question about Sony Playstation 3 (PS3) Console
Ps3 stops updating around 53%
My ps3 will not update past 50% or so, its stuck in a loop and I cant get it out
SOURCE: carried out an update, but now stuck in loop
Procedure for Entering Safe mode when PS3 is caught in update loop:
When you first turn on the PS3, it will not allow you to go into Safe mode. You must prepare it for this.
link for flash drive prep:
http://www.us.playstation.com/Support/SystemUpdates/PS3/pc_update.html#update_PC
(This will not work for the drive that currently is caught in the update loop. You must take the hard drive out of the PS3 and temporarily replace it with another 2.5” SATA drive. Note: temp drive may need to be initialized… Connect drive to pc, right click on My Computer and select Manage… Then select disk Management… you will then be presented with a dialogue box that will assist in initializing the disk.. However, only initialize it… Do Not Format it!(waste of time) Once the disk is initialized disconnect it from external enclosure or shut down computer and remove disk)
From the top:
1.) Plug in PS3 and flip switch in back of PS3 to on. Red LED in front of PS3 should light up. Also, plug in Controller at this point.
2.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then a final beep and the PS3 will power off again and Red LED will be on
3.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then two beeps
4.) As soon as you hear the two beeps, hold PS button on Controller
a. You will then be presented with an options screen
i. Restart System -- leads back to update loop
ii. Restore Default Settings --
iii. Restore File System -- leads back to update loop (8002F14E)
iv. Rebuild Database --
v. Restore PS3 System --
vi. System Update -- will cause error
5.) You will then remove the temporary SATA drive from the PS3 and replace it with the hard drive that is caught in the update loo
6.) I am currently stuck attempting to Restore Default Settings and Im sure it will end in error, but i have to try all possible solutions.
Posted on Oct 15, 2009
FFPro
  • 66 Answers
SOURCE: PS3 UPDATE FAILURE
okay you mite wanna try it again if it happens try to download the PS3 update that is needed onto a disc or a usb. Then put the disc or Usb in the usb port, or the disc in the driver and upload onto the PS3
Click the Thanks Button
I tried all I can to help you!
Posted on Mar 27, 2008
ginko
  • 19396 Answers
SOURCE: ps3 error 8002f14e
That is Failed Software Update, when that happens the system gets corrupted and cannot load anymore.
All you can do is downloading the update into an USB stick , plugging the memory stick into any of the USB ports on the PS3 and try to run the update again. Do it a couple of times.
If that does not work contact Sony, in some case they will replace the playstation becvause of this error.
Posted on Jul 05, 2009
  • 91 Answers
SOURCE: i cant update my ps3 because an error comes up how
are you doin it via internet?? if so try downloading the update to your computer and use a memory stick. what is the error number?
Posted on Dec 17, 2009
shami11136
  • 66 Answers
SOURCE: error code 8002F1F9 is a pain!!! I am stuck in the
try to format it first ok, choose the custom format->FULL system format it will take 2-3 hours so dont panic, just format it, now if it doesn't work just go to the nearest PC store and buy ur self a brand new laptop hard disk with any size u want and replace it with the old one, but format FIRST okkkkk
Posted on Jan 24, 2010
MY PS3 TRIES TO UPDATE BUT STOPS AT 53%
Your update file is most probably corrupt or wireless internet is disrupting.
Try re-downloading it again
Also try the option to update it via USB instead of wireless connection.
USB is usually very fast and reliable
Mar 12, 2011 | Video Game Consoles & Games
Hello, My Playstation 3 is stuck in loop for updating 3.30 system software update. Everytime it stops at 36% and gives an error 8002F147. I have tried several things like formatting the HDD on a PC to...
go here
http://faq.en.playstation.com/cgi-bin/scee_gb.cfg/php/enduser/std_adp.php?locale=en_GB&p_faqid=4545&p_created=1248687438&p_sid=RuRqLn-j&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzgsNzgmcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9c2FmZSBtb2Rl&p_li=&p_topview=1
Jul 25, 2010 | Video Game Consoles & Games
Stuck in the update loop with error 8002f1f9
I had the same problem... Just fixed it today..
Just before I had the update loop problem, my bluetooth on the PS3 went. I could only use the controller whilst connected to the USB port.
I replaced the bluetooth/wifi board
Jan 27, 2010 | Sony Playstation 3 (PS3) Console
Downloading ps3 update and I'm stuck on a error loop
hey mate!
i had the same problem as you have with a 40 gb model i bought with a ylod and fixed. after i assembled it i tried to update the firmware but it got stuck in a loop between 69 to 70 % and wouldn`t finish the install. after doing some research i found out the the error number that appeared (cant remember the number now) happned because some hardware wasn`t connected the way its suppose to,when 69% will indicate the blu ray drive,and indeed i noticed that the clip on the ribbon was broken . i had to use a piece of cardboard at first to shove it right to its place nice and tight and started the ps3 again , (failed again because my wifi antenna wasnt connected, but after i connected everything...) the update finished and i was a happy man!
so if your ps3 have been opened in the past , there is your problem.
hope i healped and good luck!
Jan 08, 2010 | Video Game Consoles & Games
PS3 Update successful,install failed,systemrebooted,error8002F14E
On the playstation 3 site error code tool says this code is an issue updating the PS3 sytem software. Try to start with the hard drive uninstalled then try again installed. If that dont help i would format the hard drive in a laptop and see if it helps. worst casr scenario you could dissasemble the PS3 and unplug tha battery on the main board and see if that helps. Good Luck
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Ps3 error 8002f14e
Jul 05, 2009 | Sony Playstation 3 (PS3) Console
PS3 + UPDATE = bad for me
Sounds like your stuck in a firmware update loop.
See what happens when you boot the PS3 with the hard drive out.
Do you still get the same menu on screen?
Jun 19, 2009 | Sony Playstation 3 (PS3) Console
Carried out an update, but now stuck in loop
From the top:
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Updating killzone2, killed my ps3
If you get stuck in a loop like this, most of the time it's because you have bad sectors on the hard drive and / or the drive is failing.
If you have a spare sata drive around I'd swap it with your current PS3 drive and see if that corrects the problem
Since you're using a new drive the PS3 will require an external usb drive hooked up with a copy of firmware 2.60.
Check out my guide below:
http://rescuetechla.blogspot.com/
I'm still working on my guides so if anything is confusing just let me know and I'll explain further.
Hope this helps.
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
I tried updating my ps3 to the recent 2.36 update, it downloaded, and i agreed with the terms and everything. When it was time for installing the download, it stops at 29 percent, and teling me that there...
Hey davefearon,
If you are unable to get back to the Playstation 3 dashboard, your console may be stuck in an installation loop. Unfortunately, this typically means that you would need to contact Sony to arrange physical repairs on your PS3.
On the other hand, if you can get back to the PS3 dashboard, you may want to try updating the console using your PC and a USB flash drive instead. You should be able to find instructions on how to do so in your owner's manual, or can visit Sony's support website by clicking on the link I've provided below.
http://www.us.playstation.com/PS3/About/SystemUpdate/pc_update.html#update_PC
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 18, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
119 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
