Question about HP Pavilion a220n (DK218A#ABA) PC Desktop
Hp pavilion desktop a220n
When I turned on my desktop today, it only ran for about 2-3 seconds and then shut down. I tried again and again, then unplugged it and waited, plugged it back in and still, it shuts downs in 2-3 seconds.  I have never had any problems with this computer before in the several years that I've had it.  Please help!  MaryS
  • 749 Answers
Check the fan (top rear of the computer) , make sure it runs when you start the computer. if it is NOT running the power supply may be the cause.
also you may need to remove the case and inspect the fans inside. you shoulkd be able to remove a couple phillips head screws on the back of the computer and lift the cover off or at least the side making the guts of thhe computer visible.
once open , inspect all the fans and cables, especially the fan on the main board and the metal piece with fins undernieth it, this tends to collect dust causing the cpu below to overheat and shut down the syatem to protect itself. The number one cause of crashes is overheating.
look at these things to start and post your findings and we'll move on to another step.
Posted on Oct 23, 2008
My HP Envy Phoenix H9-1330 fails to boot it makes it as far at the HP logo then shuts off.
Make sure all your power cables are in tight (both ends), and try a different power outlet.
Jun 25, 2014 | HP Pavilion Computers & Internet
E- computer turn on then the screen says it was shut off improperly. say click to restart or wait.....did this it ran through its process and went to screen with no signal. ran it again under boot and...
sounds like your windows installation took a hit, try booting from the windows cd into the repair console and do a chkdsk /F /R; a fixboot and an fixmbr command. if ths doesn't work, try the repair option. You can also try to boot from a hirens boot disk and try the tools that come with that.
Jun 17, 2011 | E-Machines eMachines Desktop PC
The power button on my HP monitor keeps getting a message saying "Power button lockout" and the monitor will not turn off whenever i push the power button it just goes to sleep and i have to unplug it and...
Hold down the power button on your monitor, with the power on, for approx. 25-30 seconds and the monitor will shut down for good. When you will start it again, wait at least an hour, the message will be gone and the monitor will work as intended.
Jun 23, 2010 | Computers & Internet
Freezer runs for 2 seconds then stops, and runs this cycle.
Good day,
The shut off is due to the protective overload mounted on the side of the compressor to shut it down, if it can't start.
On the side of the compressor is a cover box that contains the overload device, a start relay, and on some models, a start/run capacitor.
These items can to a degree tested with an ohm meter, but it is wiser to take them to an appliance parts house for testing.
If any are found defective, replace them. If not, the compressor has failed internally and needs to be replaced. Close to $400.00 if not more.
Feb 06, 2010 | Freezers
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Jan 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
Alienware Aurora desktop crashes on bootup
try to change the cooling fan mayhbe its the problem that your proccessor is over heated.
Dec 25, 2008 | Alienware PC Systems Alienware Aurora High...
Region Error
please try if this helps:
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. turn off.
10. Turn player off then on again.
11. Player is now region-free.
Nov 02, 2008 | Samsung HT-X250T Theater System
Shuts down it self
Sounds like you have a heat issue. Is the fans clear, or are they clogged with dust, hair, etc? Check the cpu heatsink as well for dust, etc. It sounds like the cpu thermostat is shutting the system down. Let me know
Aug 18, 2007 | AcerPower Se PC Desktop
HP Pavilion a220n (DK218A#ABA) PC Desktop Logo
265 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
