Question about Whirlpool Washing Machines
Whirlpool 6th sense washing machine dreamspace - stops running A FL dl symbols what do they mean
Symbols A F FL DL what do they mean?
localwonder
  • 6784 Answers
SOURCE: Washer won't start and we're getting the symbols
Hi, this (F-dL), is a code that represents a failed door locking mechanism. you will have to check the wires leading from the control board to the door lock mech. test with a Ohm meter for resistance. if you pick up ant readings and, the door lock isn't functioning, it is time to replace this device.
In most cases, you will have to replace the door locking mech.
Posted on May 17, 2009
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet troubleshooting
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$
Posted on Sep 28, 2010
TheMobilian
  • 8220 Answers
SOURCE: hi, my whirlpool aquasteam 6th
Might be wrong soap, too much soap, soap in wrong tray, heater or thermistor broken, hoses backwards, no water being sensed going into the machine, no water going out, and me fave: leak detected. More HERE
Get a free service manual HERE
Posted on Dec 11, 2010
SOURCE: My Whirlpool Washing Machine 6th Sense 10kg
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Posted on Oct 30, 2011
6th sense washing machine showing fault dL. Any ideas ?
Sometimes faults mean bad circuit board. for (front loaders)
Feb 11, 2016 | Washing Machines
Why is the water level so low? In my machine the water level is so low that all water is absorbed by the clothes and no water is noticeable around the clothes.The machine fills water for 1 minute. Bot
If you have a brand new machine with a little pimple of an agitator in bottom of tub, these are the new water saving models. You will have to get used to it. This new and improved design is driving people crazy. If this is an older machine your inlet water valve is clogged probably due to hard water. You can clean out, or replace. GOOD LUCK FRIEND.
Nov 05, 2014 | Whirlpool Washing Machines
Whirlpool GHW9400 Door will not latch. Washer turns on, Starts clicking then flashes dL F
Hi, DL means Door Lock Failure while F is either (F80, 82,
84, 85).....
DL flashes if the following conditions occur:
  • Door lid is not closed completely due to interference.
  • Wash media buildup is preventing the lock bolt from extending.
  • Machine/motor control detects open door lid switch when attempting to lock.
  • Machine/motor control cannot determine if door lid is in a locked state.
Oct 03, 2010 | Whirlpool GHW9400 Duet Washer
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
Mar 15, 2010 | Whirlpool Washing Machines
My front load locks and i get a error code fL 11 and dL
u need to change the main board. DL is a door lock error code
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start and we're getting the symbols ''F'' and ''dL''
May 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What is code dl on a whirlpool washer?
dl stands for " door lock "
you may have a problem with the door latch. it does not detect that the door is already close to run the unit. it is sensing that the door is still not locked.
tnx 4 using fixya,
drcool
Sep 17, 2008 | Whirlpool Washing Machines
Washing Machines Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
