Question about Bushnell Optics
Have a bushnell scopechief IV where can i find a manual that explains the correct operation of focus wheels
Just want read about all adjustment features before i mount it on my son's rifle
magoo23
  • 22 Answers
SOURCE: bushnell sportview 4x12x40
daystate is based in the UK so you may not like this answer too much. The oldest manual for daystate rifles and accessories only go back to 97'. however, here is their contact info to try for some help from the people who might send you the manual in paperback or mabey as a pdf if you email them. +44(0)1782 791755 their phone and sales@daystate.co.uk email link. it's worth a try. otherwise you may find someone who owns your rifle mode on their site's forum
Posted on May 06, 2008
SOURCE: Bushnell Sportview rifle scope wide angle 4x38 T4389 limited adjustment inconsistant results
I had the same problem but was able to solve it by shimming the scope mounts with a thin piece of plastic. Put it under the rear to raise the sighting and under the front to lower. I still plan to buy my son a better scope.
Posted on May 18, 2008
  • 112 Answers
SOURCE: Bushnell 10 - 30X50 adjustment
on some models the center focus control is located on the center hinge,it should be flat,and not hard to find,if there is no center wheel this is where it should be...good luck...larry@reichinstruments.com
Posted on Nov 27, 2008
SOURCE: what is the focus and mount type and size of the
Right here- look down the web page for 78-6114
http://www.bushnell.com/customer_service/manuals/telescope.cfm
Posted on Jul 05, 2009
  • 86 Answers
SOURCE: Sighting the Bushnell Holo Sight
here is were you can download the manual
http://www.retrevo.com/support/Bushnell-51-0021-manual/id/8328bh538/t/2/
Posted on Jul 29, 2009
What does the 15 ys mean?
How to Zero Your Rifle Scope: 15 Steps (with Pictures ...
www.wikihow.com > ... > Guns and Shooting > Rifles
wikiHowLearning to properly mount, sight, and adjust a rifle scope will result in accurate shots and saved ... MESSAGES. LOG IN ... Start with a good quality base mount and mounting rings to ensure that your scope will be held sturdy for years to come.
Aug 30, 2015 | Optics
The reticle on my konus pro 4 x 32 does not move when i adjust it
Are you trying to see the reticule move? Or are you shooting after moving the adj screws??? You won't see the reticule move, It only moves maybe 1/4 inch max both ways, If you have a bolt gun, mount the rifle in a vice or a cardboard box with v's cut in it to hold the rifle, aim at a given target app 100 yards away, then sight down the bore, you should be able to see the target, if not, line up the bore, then adj the scope to it, you will be on paper at 100 yards, Try it.,,,,, also, the cross hairs are mounted in a tube that is adjustable, the wires themselves are fixed.
Apr 17, 2012 | KONUSPRO 4X32 MBLK KON7262
How to sight in crosman extreme g1 pellet rifle scope
You would sight in an air rifle scope in the same manner as any other standard scope that you might find on a rifle:
You want to secure the rifle as best you can with the sights pointed towards a target, which should be set at the desired distance.
Reduce the error of your sight adjustments either by mounting the rifle in a gun mount or simply resting the stock (not the barrel!) on a solid surface such as a table.
Make sure that the weight of the rifle is carefully supported and the **** is firmly pressed into your shoulder. Looking through the sights, aim at the very center of the target (which for your purposes can be as simple as a piece of paper with a dot drawn in the middle).
Take time to ensure a careful shot, and be sure to avoid any shaking, utilizing the support of the mount/table (try resting the fore-grip of the stock on a roll of paper towels if you're having trouble keeping the rifle steady).
Once you are confident with the placement of the cross-hairs over the center of the target, gently squeeze (don't pull) the trigger.
Determine where the pellet struck the target, and adjust the scope accordingly; while every scope is a little different, the same basic principles for adjustment apply. Unscrew the caps on the top and side of the scope, and carefully read the markings on the adjustment dials.
If the pellet struck low, twist the dial on the top of the scope 'up' (the markings should specify clockwise/counter), and if the pellet struck high, twist in the opposite direction. If the pellet struck to the left or right, follow the same procedure for the dial on the side of the scope.
If the pellet struck low and to the side, make the vertical (up/down) adjustments first, repeat the shot, and only move on to make adjustments left/right once the pellet strikes in vertical alignment with the center of the target.
Take your time, and adjust in increments of only 2-3 clicks to start. Repeat the procedure until the pellets are striking consistently in the center of the target (if you're having a hard time remembering which shot went where, replace the target and continue.
Once you are satisfied with placement of your shot groupings on the targets, replace the dial covers on the scope.
Tips and Notes:
- In order to maintain the accuracy of your rifle, try to avoid resting the rifle on its scope and try to prevent the barrel from contact.
- Take note of your rifle's range, and be aware that the further away you place the target, the less consistent your results will be.
- Be realistic; don't attempt to sight in an air rifle at 50 yards. Remember that even with a rifle that has been professionally sighted, good results still come down to the accuracy of the shooter.
-Sight in your rifle at a range where you are confident in your own abilities; start with a closer target and only move back (i.e. sight in at a greater distance) if necessary.
Further Instruction:
http://www.chuckhawks.com/sight-in_rifle.htm
http://www.youtube.com/watch?v=lLirsAFpsfE
May 05, 2011 | Sport & Outdoor - Others
How to readjust a weaver mount?
Make sure the nuts are on the same side of the rifle (both on the right OR left). The clamping mechanism can vary the centering of the scope if they are on opposite sides of the mount.
The other problem may be poorly drilled mounting holes on the receiver or scope mount, check these for alignment with your bore or barrel.
Mar 15, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
I have a redfield 3x9 rifle scope and looking for tips on sightin
Yes thats about all there is to it, adjust in small steps and tap on the barrel of the scope with a screw driver handle (light taps) after each adjustment before firing the gun.
Nov 14, 2009 | Redfield See Thru Rifle Scope Mount Base...
I have a model D-4 weaver rifle scope with missing adjustment par
Pretty much all rifle scopes have great warranties. Send it into weaver and i'm sure they will fix it plus replace any parts. I'm sure they will charge for missing parts but it would be best for them to look at it and check it out. TP
Apr 07, 2009 | Weaver Optics
Rifle scope is hitting 5 feet high but dead center
mounts are probably too high.....had the same prob on a .22 rifle with high mounts for open site shooting also. i bought a lower mount and zeroed it in with no prob
Nov 24, 2008 | Bushnell Sportsman 4x32 Riflescope (4x32...
Mar 02, 2008 | Optics
Scope
Follow these steps
1) Mount your scope.
2) Use a bean bag or rifle mount and make sure that your rifle doesnt move much from its original position throughout this process.
3) Aim with the scope and shoot at a large backstop which will allow you to see where your shot lands, where ever that may be, it doesnt matter at this point. Again, make sure your rifle doesnt move much when firing.
4) With the rifle in the same position, look through the scope and adjust the crosshairs over to where your shot landed.
5) The scope now sighted in with the rifle. Minimal adjustment may still be required but at least your well within the ball park.
Happy Shooting
Nov 13, 2007 | Bushnell Trophy Multi-Reticle Red Dot...
Optics Logo
276 people viewed this question
Top Bushnell Optics Experts
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
