Question about Microsoft Xbox 360 Console
Red light on power brick
Red light no power to consol. will not turn on when hit power button
  • 2 more comments
  • Anonymous Nov 23, 2008
    mine stays a yellow light until i plug the end into the back of the console causing it to instantly turn red
    same prblem
  • Anonymous Jan 02, 2009
    red light on ac adaptor xbox wont turn on
  • Anonymous Feb 14, 2009
    my ac adaptor light stays orange until i plug it into my xbox 360 then it turns red.
    Novelist:
  • 67 Answers
Hi ntwrk11,
This happened to me before also. What I learned is that this either means that your console AC adapter (the big power brick) is not getting enough power or is not properly plugged. If this is the case, I would suggest that your try plugging the console to a different wall outlet, and make sure not to use any UPS, surge protectors or power strips to plug in your AC adapter. See if that works.
Also please check the back of the console and see if the power connector at the back is firmly seated, and even if it' seated, I would still suggest that you reseat (unplug and replug) the power cord at the back of the xbox360.
If the above suggestions don't work, and you have another xbox360 or if you know someone who has one, it would be much better to try swapping AC adapters and see if you get a response if you try a known working AC adapter on your console and you will also isolate the problem if it's your game console or just your AC adapter that has the problem.
If all else fails, you may have to call up microsoft for further help and support, since your problem may require servicing of your console.
Hope this helps!
Peace! :)
Posted on Oct 23, 2008
  • 28 Answers
I don't know how to fix it if it happens randomly other than to let the system cool down and re-plug it in 10 minutes later
if you mod the 360 (i.e. Xclamps, fans etc)
it has been noted to be caused by a short of the grounding, try loosening the screws slightly on the metal casing and the 3 screws by the power button, it worked for me - hope this helps,
josh
Posted on Feb 07, 2010
**** microsoft. they will charge us $80 just to get it fixed
Posted on Nov 05, 2008
4 Suggested Answers
repairtech99
  • 767 Answers
SOURCE: Hi, I have an xbox that shows orange on power
If you watch the power supply light it will probably
flash red for a 1/2 second then orange . And if
the fan shuts off then you have a shorted regulator and
it's normally the two closes to the Ring of lights P.C.
board plug . I have swapped those parts out before
but their tough to get of the board with out the right
tools ( reflow wand) the cost of repair shouldn't be
more than 60.00 -80.00 so shop around for the
best warranty.
Rob
Posted on Apr 15, 2010
bfready
  • 149 Answers
SOURCE: When i hit the power button the fans try to turn
Hardware problem. Most likely a break in a solder connection on the mother board and cpu. You need to send it to Microsoft to get it repaired. There is an extended warranty on the 3 ROL, so it will be free.
Here is the link to Microsoft Support here . Sign in and submit a service request.
Posted on Oct 04, 2009
SOURCE: xbox wont power on past orange brick light
You need to have the 3 red light fix service. We can fix it for you. We are a listed repair service on this site. Here is a link to our 3 red light service.
http://www.videogamerepairservice.com/catalog/item/5675532/5556610.htm
Posted on Dec 08, 2009
No power getting to console power pack orange light i have tried unplug use different power cords talk microsoft no help
are you sure its not yellow try moveing wall sockets better yet hit the disk tray button if the brick cant supply enogh power it will then turn red or yellow if it stays orange it in stanby witch means it could be many problems if the system cant get enogh power to turn on it will show the 3 red rings but if the brick does change the brick is done
Dec 22, 2010 | Microsoft Xbox 360 Console
The power brick on my xbox 360 is red and is not overheating yet i smaell burning plastic from my xbox 360 console anyone have any tips?
A red light on the xbox 360 power brick usually indicates the Xbox 360 console has a short circuit. Here is how to be sure:
1. Try unplugging the power brick from the wall and from the xbox 360.
2. Wait about 30 seconds and plug the power brick into the wall power outlet.
3. Make sure the indicator light on the power brick is orange. ( If it's not orange then get yourself a new power brick and try again ).
4. Plug the power brick into the Xbox 360 console and try to power it on.
If your power brick turns red or you get an immediate three red ring error than you will need to have the console professionally repaired.
If your warranty with Microsoft has expired; the company I work for GATpro Repairs offers this service at a low flat rate and we pay for the return shipping.
Good Luck and I hope this has helped!
Michael GATpro Repair Technician
Jun 14, 2010 | Microsoft Xbox 360 Console
Xbox wont power on past orange brick light
Dec 08, 2009 | Microsoft Xbox 360 Console
Power brick going red right as its plugged in
Sound like a short fet /L.D.O.R or a solder bridge under one of
the chips , you "worked" if you used a heat gun , there
is more than likely sever board warpage. A scratched
or broken trace will not trip the 1.8- 3.3 volt standby over current
(red light on the brick) it's normally a solder bridge.
but i could be wrong ,hard to tell with out line tracing
the caps with a scope.
Rob
Nov 11, 2009 | Microsoft Xbox 360 Console
When i hit the power button the fans try to turn over and the power brick goes green but then they fans stop and the power brick goes yellow/orange. And then i get the 3 red lights
Oct 04, 2009 | Microsoft Xbox 360 Console
Xbox 360 power brick turns rd when connected to console
When the light turns red that means the power brick is to hot.
Dec 26, 2008 | Microsoft Xbox 360 Console
Power cuts off
Might be a faulty power supply mate , when you turn the xbox on observe the power indicator on the power brick.
Green means its okay
Amber means the console is in standby
Red means the Brick has had it.
Try a friends power brick to see if it does the same.
jonno
Sep 03, 2008 | Microsoft Xbox 360 Console
XBox 360 power problem
The power brick has most likely died.
Dec 14, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
6,429 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
