10.2 inch nikkai hd tv. hd not supported
Get sound but no picture. keeps coming up on screen hd not supported
  • 213 Answers
SOURCE: sound but no picture on Bush HD 32 INCH TV
is this a lcd/or pl/ crt,
if crt you can see if you have g2 look at the nick of the tube to see if the filment are lit up
so tack off the back now plug the tv in now hook up cable to it now tune it on .how look at the nick
you see the ken bord on back of your picter tube.
if you see a glow you have g2. on the flyback you see screen livi. ture it up a litte. and see if pix come back if do then you fix it if you saee a line then v.ic is bad. if the ic is bad you will not git a pixt
Posted on Aug 10, 2009
circuitworld
  • 335 Answers
SOURCE: my ASTAR 32 inch has no picture or sound for 10
You have an AC resistance problem on the interface board. Passive components such as silver mica and electrolytic capacitors are not charging and discharging properly. This causes a delay or disruption in the start-up process. Byte signals are weak and intermittent due to other thermal components failing such as 'diodes, smd mosfets,...etc...''' Believe it or not this happens from manufacturers using 'inferior-grade' circuit components that fail under considerable load conditions. By replacing a few parts with better quality parts will solve this issue for you. To replace these parts requires removing the back cover and using some test equipment. If you can get someone who is technically proficient I can e-mail them instructions on how to fix this problem on the circuit board.
Let me know if you want to follow up on this...
Posted on Dec 07, 2009
  • 541 Answers
Most likely you have an inverter problem. The inverter powers the backlights so that the picture can be seen. You can try holding a flashlight close to the front of the screen in a dark room and if you can see any trace of a picture, the backlights are not lit. This can be a pretty hot circuit to work with. Have a shop check it out for you. Thanks for using fixya.
Posted on Jan 12, 2010
  • 63 Answers
SOURCE: tv keeps turning on and off
You probably have blown capacitors on the PSB-power supply board. Recaping with new UF caps works 90% of the time. The set turns itself of into a fault protection to keep from damaging more components internally. A few bucks a soldering iron some solder should do the trick.
Posted on Jun 30, 2010
welcomejee
  • 10594 Answers
SOURCE: my LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Posted on Jul 23, 2010
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
I have a panasonic 3d blu ray player with internet built in. I have my system wired to a hdmi switch and then onto wireless nikkai video sender to my projector this gives me a 100 hd inch screen with...
Try connecting the Bluray player directly to your projector and verify if you have the same issue. If you do not have an issue, your switch is causing the picture to freeze.
Aug 24, 2013 | Audio Players & Recorders
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
My ASTAR 32 inch has no picture or sound for 10 mins on start up. Happens if tv has been turned off for a couple of hours. I get blue screen then snow screen and eventually picture will come up but may be...
This is typical of dried up old capacitors. The problem can be cured by keeping the TV on for days. The moisture in the air will be the cure for the dried up capacitor. It will be good as new if you use more frequently.
Nov 04, 2010 | Televison & Video
Picture goes off on its own
BAD SOLDER JOINT ON L14401
Apr 11, 2009 | RCA F36650 36" TV
No picture but has sound
have a 42 inch rca 42PA30RQ NO PICTURE OR SOUND WHAT CAN I DO MY SELF BEFORE SPENDING A LOT OF MONEY TAKING TO A REPAIR SHOP
Dec 14, 2007 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
