Question about Kenmore Elite 45986 Front Load Washer
F02 Error on Front Load Kenmore HE3
I was getting F02 code flashing on my display. I cleanup all the hoses but still was getting F02. I called "the expert" he replaced the pump - still the same F02 showing, then he replaced water level sensor - F02 showing up. At the end he replaced the the computer - F02 showing again. Is there anything else I can do? Or should I buy a new washer?
Thanks
BM
  • 1 more comment
  • honeymrs Oct 23, 2008
    My washer just started the F02 error. I can't find my user manual. on all of the posts I've seen people say the F2 error is a draining problem. I am trying to figure out just what the problem is before I call a repair man.
  • srohit Jan 02, 2009
    Washer's filter was blocked with rug's goo and draining was taking lot longer than 8 mins. Cleaning the filter took care of the problem.
    I had to open the washer from behind, reach out to drain access plug between machine and pump, clean it out throughly.
  • Anonymous Mar 28, 2014
    Maytag Maxima MHW6000XW0 stops and beeps, displays alternating error code of E01 and F02
    Novelist:
    Champion:
  • 261 Answers
F 02 Is your key pad user interface that has failed. I would call back and get some free service from a different technician.
Posted on Oct 23, 2008
Getting F02 error on Kenmore Elite HE3 washing machine............how do i fix problem?
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
• Check the drain hose and make sure it is not plugged or kinked.
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects.
• If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap. Hope this helps... Please post back for more information.
Daniel
Nov 26, 2010 | Kenmore Washing Machines
F02 error code
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!$!$
Jul 24, 2010 | Kenmore 42822 Front Load Washer
F02 error
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Mar 25, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
We are getting an F02 reading. The hoses are
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. Check the drain hose and make sure it is not plugged or kinked. Check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. If the above does not correct the problem, replace the pump.
Jan 06, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore HE3 front load washer will not drain or open door
Nov 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have kenmore elite he3 and it is flashing f 02 and then it will flash sud. Water will not all drain out of it,
HI. this code represents a Long Drain issue.
Potential Causes
Oct 27, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Getting an 02 F flash
F02 Long Drain
Potential Causes
Aug 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE3 front loader keeps getting F02 error message, most often when I wash towels. I was able to workaround by pulling half the load, but that no longer does the trick.
Long Drain
F02
Potential Causes
Jul 13, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 Code F032
I remove the pump and found out that the impellor was worn , I have replaced the pump and the machine is working , no more F02 Codes .
Nov 14, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Jul 07, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,854 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
