Paper won't feed/cut at all. It makes some loud noise when you put the paper in.
SOURCE: fellows paper shredder
First try to clean those sensors with a qtip dipped in rubbing alchohol if that does not work call 1-800-945-4545 to check for part availability.
SOURCE: novitech shredder
After clearing the jam (with the unit unplugged!), let the unit cool completely, then try using it again. A notice on the nameplate inside my unit says: "2 min on/4 min off." Apparently, a thermal cutoff keeps it from overheating by automatically preventing continued operation that might otherwise melt the parts. So heed the directions. I had the same problem with my NoviTech Model PS-026/B2 crosscut shredder (max: 5 sheets, 1 credit card). Also, make sure the motor mechanism is seated square and flush on the bin. I tried testing it out of the bin, and the green ready light wouldn't come on -- for a good reason: safety. (I still have all of my fingers, thanks to that!) Hope this helps.
SOURCE: Shredders on but is not working?!
you need to make sure that the paper detection sensor is not stuck or full of paper dust.....
SOURCE: durabrand shredder model wm6x runs in reverse but not forward
Try cleaning the sensors with a cotton swab and alcohol.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
