Question about Bosch Irons
Bosch TDS 2510 Sensixx B25L
JUST CLEANED AND LOTS OF HOT WATER SPITTING OUT
4 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: bosch sensixx b25l need to Descale ASAP
Is this it? http://www.bosch-home.co.uk/our-products/ironing/ironing/steam-generators/TDS2556GB.html?source=browse
The left hand column of that website has a "download product manuals" link, follow that, click "Click here to download product instruction manuals." then the model number is TDS2556GB/01
Posted on May 26, 2010
SOURCE: bosh sensixx B25L iron spraying brown water
I have a bosch sensixx b25l and it has started spraying brown water all over the clothes how do I descale it please
Posted on Apr 20, 2011
  • 244 Answers
SOURCE: I have a Bosch Steam
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
Posted on Jun 02, 2011
Bosch TDS 1445/05 Sensixx station doesn't making steam
HI!
I HAVE AN Bosch TDS 1445/05 Sensixx AND THE IRON PLADE NOT WORM AT ALL. I CHECK THE POWER.I CHANGE THE THERMOSTAT/THE CONDENSER WITH THE LAMP/.BUT STILL NOT WORK. THE BOILER WORK GOOD.PLEASE HELP ME.WHAT CAN I DO MORE. THANK YOU
Oct 06, 2012 | Irons
Bosch sensixx B25L no steam
Are you sure that you have the correct settings chosen? It sounds like you have a faulty unit!
Sep 26, 2012 | Bosch sensixx TDA 8333 Iron
Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Jul 31, 2012 | Bosch Irons
HI I have a Bosch Sensixx B25L iron. Steam isn't coming out of holes, seems to be escaping from edge of iron. Handle very hot (Too hot to hold on to), burns your hand when steam button is pressed
I just fixed mine - it had exactly the same problem.
First, though, check it's not within the Bosch TWO year guarantee; if it is, they'll either fix or replace it.
If it's not under guarantee then the problem is probably the rubber tubing that connects the external steam tube to the hotplate. You'll need to dismantle the iron. Mine had split right next to the spring clip that holds it on. I shortened it, clipped it back on and all is now well.
Jul 28, 2012 | Bosch sensixx TDA 8333 Iron
Bosch sensixx b25l manual
Though tpmy iron is heating up it won't take the water in and so doesn't steam It has been cleaned and no scale is in the bottom. It worked fine yesterday.
Jan 11, 2012 | Irons
I have a Bosch Steam Generator Sensixx B25L. It has suddenly started leaking water from the back out of the plate. This only happens when the steam button is pressed and the handlegets very hot with it. ...
Jul 27, 2011 | Irons
Bosh sensixx B25L iron spraying brown water
Feb 22, 2010 | Bosch Irons
Irons Logo
85 people viewed this question
Top Bosch Irons Experts
Colin Stickland
Colin Stickland
Mark Chaney
Mark Chaney
matt
matt
Are you a Bosch Iron Expert? Answer questions, earn points and help others
