On/Off switch will not turn unit on..sunk in
The on/off swith will not work, (sunk down in). I took all the screws out all around botttom of unit. Can't figure out how to take the screen off to get the top screws out to left the top chassis off.......Help
  • 348 Answers
That unit may have the locks open it by screw driver check the power at cord then insert and check ac voltage at fuse if present then check after fuse if not then replace it then check dc voltage across big capacitor if not then check 4 diodes if faulty replace it if dc volt is very low then replace capacitor problem may solved
Posted on Oct 27, 2008
How do you replace a GE Spacemaker Oven Profile JVM1490WD003 handle ?
usually you need to demount the front panel
then remove its face unit as it will have a back guard unit
so they split apart with screws usually counter sunk machine screws
then the front unit section will have the handle attached
de mount it and replace and back step
i find if i place all the screws like a map of where they came from
then when placing a screw in metal or plastic
turn the screw anti clockwise {to the left}
till it clicks down and drops a bit
you get a feel for it so practice
once you do this you can almost guarantee your on the correct threads when you wind it clockwise {to t he right} to secure
esp important with plastic
if you drop in the wrong thread you end up with a unit thats plastics holes
no longer hold the screws turn turn isnt good
when you can use this trick
Aug 14, 2014 | GE Profile Spacemaker Over-the-Range...
1993 Subaru LX Liberty with a EJ22 2.2L Engine Overheat problem?
I have the same model, and had the same problem 2 years ago- random overheats. Problem turned out to be the thermostat installed upside down. The thermostat should be fitted so the operating part with the spring goes up into the engine block. A similar problem I have now is overheats and coolant loss out the expansion tank overflow, specially during wide open throttle driving. Also bubbles in the radiator. Seriously suspect head gasket failure.
Sep 02, 2012 | Cars & Trucks
Pfaff creative 2134.....needle is hitting the bobbin casing
There is two possible solutions. either the machine has been knocked out of time by a thread jam or the needle rod has been bent. Good Luck!
Apr 19, 2011 | PfaFF Sewing Machines
How do I open it to get access to change the belt?
All maytags i have encountered open from the front. There should be two screws at the bottom of the front or under opening of door. The top pops off and opens up to lay back. Swing front over to side of machine being carfull of door switch wiring.Look through botttom of dryer and you will see motor and idler pulley setup. belt is routed around drum, under pulley and around motor shaft. Hope this helps.
Dec 25, 2010 | Maytag PYE2300AY Electric Dryer
92 buick lesabre, left blinker won't work unless you move it manually. bulbs and fuse are fine. hazards work.
Hi Friend:
Since you've check or Changed your Bulbs and Fuse also Check or Replace your Turn Signal Flasher,Just as a Percation i would Double Check Fuses,Bulbs and Signal flasher.
If these are All showing bad I would say your Signal Switch has Stopped Working.
To Replace the Signal Swith :
1st Disconnect your Negative Battery Cable.
Remove Steering Wheel (you'll need a Puller, the remove the Shroud around the Steering Wheel Colume.
CAUTION= If you have Air Bags be careful. But you will have to remove the Air Bag Module by removing the coil lock spring Screw.
Then remove the Retaing ring and Coil Spring it will still be attached to your wiring=Just let it Hang.
Next you'll need a Compression Lock Spring Plate Tool.
Attach it to the Center of the Steering Colume, Rotate the Nut Clockwise to Remove,After Compressed you'll see a Metal Snap ring Remove it from the Groove then remove the Tool& Plate
Now you'll need to remove the Plastic Cancel ,the ring and ALL the Bearing including the Bearing Race.
Remove the Signal Arm Lever Screw. then the Signal switch Screws. Pull the Switch out and let it Hang(Still attached to the Wiring.
Get down under then you'll have to look for the screws that hold the wiring to steering colume, Remove then.
Then remove the Retaining Rng and the Wire Plug Protector.Now you Can Pull the Signal Swith Out.
Installing New Swith Simply Reverse the Removal Directions to Install your New Switch.
Please take time to Vote on my Quality of Service and the Help i Provided And a Small Testamony would be Great.If you don't mind.
Thanks for Using FIXYA
Jul 05, 2010 | 1992 Buick LeSabre
2003 nissan altima took window down and would not go back up.30min.latter it worked.today forgot about it and it did it again.is the switch bad?how can i get the window up for now without the switch?
This may be the switch ,but most times its a motor, try to hold the swith in the up postion and bang on inside of door toward the midlle and bottom while holding switch, ig that doesnt work try to push swith for window to go up useing a little force and wiggle.the best way to find the problem would be to test motor for power and ground while operating the switch.
Jun 15, 2010 | 2003 Nissan Altima
Couldn't Turn off my 96 Grand Marquis
Seems your ignition swith has come disconected from the key switch. The actual swith is not the key. The key links to a switch on top of the steering column down around the pedals. Or the switch itself is broken free. The switch is replaceable although a pain to access. No need to pull out the steering column. Good luck.
Jun 02, 2009 | 1996 Mercury Grand Marquis
Replacing hazard swith for Honda Accord 1996
u must remove the center console....remove the ashtray..(pull it ) remove the plastic trim piece around the shifter , should just pop off ,,,held on by clips...u will see 2 phillips screws under that piece., the 2 screws that secure the trim panel that ur hazard switch is attached to.....remove those screws and gently pull the panel off , u may have to unplug the clock and otherm necessary connectors includeing the hazard switch connector to remove the panel..u should be able to remove the switch with a screwdriver..reinstall everything back the way u took it off...be sure to plug the cig lighter back in...
Apr 08, 2009 | 1996 Honda Accord
Slider switch view to take pcture
I had the same problem I just fixed today, is really easy to do it yourself the hardest thing is to disassembled you just have to take off the four screw at the bottom and there's another one in the battery compartment between Sd card slot and the 2 batteries to hold the silver plate on top is hard to see it, after you took off that little screw you can take off the top silver cover, after you took the silver cover off you'll see one more smaller screw on top of the camera under the silver plate you took off unscrew it and then separate both sides with a blade or some thing alse in mind (do it carefully it got a few small engagements around) after you did that you are ready to align the slider switch with its proper pin, youll see it. This helps to replace the lcd screen too, ones you are there. its easy hopefully it helps you
Aug 08, 2008 | HP Photosmart MZ67 Digital Camera
Interior lights don't come on when door is opened. The switches are set for door. Lights will go on if you turn to on position. Is there something else that needs to be adjusted?
Hello I have a 2008 Ford Escape XLS and I had the same problem I even took it to the dealer to be fix but when I got it back in return it only worked until I got home and stopped working again. So I took it upon myself and took off the screws to the dome light very carefully not to pull any wires I looked at it and examined it. Come to find out that under the switch I noticed one side of the copper connector was slightly burned have no idea how and why it happened. So I took a very small flat head screw driver and rubbed the burned connector that's attached to the complete unit until I saw the burn color come off and did the same thing with the copper piece I saw curled up that is connected to the switch. I only rubbed underneath it because I figure it has to make contact with the other piece i had just rubbed very carefully not to bend or break it. Once I finished rubbing both pieces I pushed down the curled up piece that is attached to the switch: which for some weird reason it was curled up I'm guessing when it burn. I pushed it all the way down until it was making contact with the complete unit. Then I pushed the switch back and forth to make sure I could feel it rubbing/making contact on the bottom copper piece. I opened the door and it worked back to normal now I was really hating being in the dark at night and couldn't find the ignition. Hope this helps everyone.
Jun 02, 2008 | 2008 Ford Escape Hybrid
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
