Question about Lexmark X4270 All-In-One InkJet Printer
Shows there is no communication between laptop & printer
I have uninstalled the printer because i have done all the suggestions when it shows an error. Is there anything else I can do to fix this problem/
  • 102 Answers
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Posted on Feb 21, 2009
X2670... printer can not communicate with computer
Hi
Did you reboot the PC after uninstalling printer?
Unplug the printer from the PC and from power.
Uninstall it from your PC and reboot it.
Connect the printer and turn the PC on.
Mar 03, 2012 | Lexmark X2670 All-In-One Printer
My printer Dell 926 is not communicating with the computer. I have disconnected the cables both from the power and tower and restarted computer but still nothing. Everything was good yesterday???
if you have the users manual (given that it has worked properly in the past) my suggestion would be to disconnect the printer from the computer/uninstall the current software/then with your manual in hand follow the guidance PRECISELY to reinstall the printer. If you do not have the manual it can be obtained (free) from the Dell site. Just before doing the uninstall/reinstall if you haven't already done so you might go to the Dell download site and install the latest drivers for the printer from there.
Hope this helps
Thanks
Dennis
Oct 28, 2011 | Dell 926 All-In-One InkJet Printer
When I click on print I get a message in a box that says "printer cannot communicate with computer. The box then has various options that might remedy the problem. These include disconecting the...
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
Mar 28, 2011 | Computers & Internet
I keep gertting this message "communication not available". I have done all the toubleshooting suggestions. The orange astrisk mark continues to blink. the cable has no kinks in it. what is my next step,...
try uninstalling all the usb hubs from the device manager and restart the computer but note that before you do that all the external devices should be unplugged. like printer , modem and anyother if there is any.
once you restart the computer automatically the hubs will get installed. also check with other usb ports.
if all this will not work then uninstall the printer driver compleately and after restarting the computer reinstall the printer driver .
May 10, 2010 | Dell 922 All-In-One InkJet Printer
Message given that computer not communicating with printer. Cable is plugged in properly, and it works with an older laptop. Tried the USB root hub suggestion above, but none were checked.
Mine seems to regularly to this. Bit of a pain, but everytime I uninstall it, then reinstall it, it works again for a while. Don't know if it's because I don't keep the printer plugged into my laptop all the time?? Try this anyway if you haven't already. Jen
Nov 09, 2009 | Lexmark X1270 All-In-One InkJet Printer
Getting %BuildTemplateErrorMessage%
Help me here, please.
What is the model number of the printer you are using?
From the very limited problem description, I 'll take a SWAG at the problem. It seems to me that the Lexmark provide software is communicating through the printer that you either have a solid failure on an existing Template or a Template was not closed properly.
If you haven't done any work on a Template, then I suggest that you uninstall the printer's software and reinstall it.
Jul 03, 2009 | Lexmark X2550 All-In-One Printer
Communication problem with scanner hp 1310 series all-in-one
The printer i was using has been deleted from my laptop and i want to re load it.
Kindly help
Jan 31, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer will not connect to toshiba laptop after uninstalling software and then re-installing nothing shows up under the Printer folder in Control Panel
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 19, 2008 | Lexmark Office Equipment & Supplies
Laptop not communicating with printer windows xp
Vista uses a different driver. Here is Lexmark Support Page:
Lexmark Support
Enter your printer (X1270) and it will take you to the tech support page for your printer. Click "Download Driver". Next page select Vista as your operating system. Next page select "Download Now". It's a large file...40MB.
Save it on your desktop and when the download is done, double click the icon on your desktop to install.
Oct 20, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark Z645 Printer
i have a problem of Lexmark Z645 Printer i want a software of this .
Feb 09, 2008 | Lexmark Z645 InkJet Photo Printer
Lexmark X4270 All-In-One InkJet Printer Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
