Question about Toshiba 36A40 36" TV
Screen Color Looks Like a Rainbow
I have a three year old Panasonic HDTV 1080i Recently the screen colors have turned into vertical color bands, starting from the left to right orange, green, blue, purple, blue, green, orange Is this thing toast? Thanks Vic Maidhof San Diego
  • 129 Answers
Good day.
The problem includes malfunctioning of you units deflection yoke, color circuit and failures in the chroma system.
Have it check by a repairman.
chris
Posted on Mar 23, 2008
Screen has too much green all of a sudden
Try balancing the tubes out, turn your color all the way down and the brightness in the middle, then find the focus block, it will be a block with 6 controls one row will say screen the other will say focus near the picture tubes, adjust the screen controls(one control for each color) until the picture has a good black and white look to it, then turn your color up and it should look fine. This is how i balance out the picture. But there is another method that allot of techs use, the other method is to adjust the brightness up until you see what is called retrace lines it is a jagged line going down the screen, once you see these lines back the adjustment down just until they disappear. Do this for all three colors. This method works but on an older set can throw the white balance off because of tube wear.
Sep 03, 2009 | Hitachi 57F500 57" Rear Projection...
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
A rainbow circle of color has suddenly appeared on the screen,
if there is a speaker near the set it will draw the color out
Jul 09, 2009 | Panasonic TH-42PZ77U TV
Dont know the contrast ratio of this tv
Specifications
Panel Type: 32" Diagonal (31.5" Viewable), 16:9 Wide Screen, Color TFT Active Matrix LCD
Panel Specifications: Anti-Static and hard coated surface
Pixel/Dot Pitch: 0.507mm (H) x 0.5107mm (V)
Display Compatibility: HDTV (1080i)
Signal Compatibility: 80i (SDTV), 480P (EDTV), 720P (HDTV), 1080i (HDTV)
Response Time: 8 ms (typical)
Colors: 8 bit 16.77 Million colors
Brightness: 500 cd/m2
Contrast Ratio: 5500:1 Dynamic Contrast Ratio
Viewable Angle: 178° (horizontal and vertical)
May 23, 2009 | Vizio VW32L 32 in. LCD HDTV
Mitsubishi WS55513 480i Signal no Color
That may be a TV problem but can also be a Cable box problem.Do you have any other 480i signals hooked to the TV?
Also most Comcast HD boxes can be set to output SD signals at 480p which may solve the problem. Usually get to the setting by turning the cable box off and pressing menu on the box, not remote.
It should display a different menu on the tv screen, arrow down to 4X3 overide then arrow right and try 480p.
Feb 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Panasonic PT-53wx53G 53' projection tv problem
was your tv hit hard,a non magnetically shielded speaker set on top or under it?
Nov 09, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Blue shadow above writing and pictures on screen
it sounds to me like your convergence boarde is bad and needs replaced
Oct 23, 2008 | Televison & Video
Projection defect
Good Day;
It sounds like you may need to re-adjust your G-2 controls, located at front, remove front panels. Look for small block with screen /focus controls on item, first turn color down, reset brightness, contrast controls. Adjust until lines are at min. and picture is a good black and white (grays). Good Luck, big IRISH.
May 21, 2008 | Panasonic PT-52LCX65 44" HDTV
Old Panasonic TV
take your set to a tech could be having problem in your video circuit or the neck board socket need to be replace.good luck.
Mar 29, 2007 | Panasonic CT-2788YD 27" TV
Cannot adjust convergence, screen has rainbow effect
You probably need to change out the semiconductors. The parts are STK392-110. There are two of them, one for horizontal and one for vertical. Search it online more.
Dec 28, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Toshiba 36A40 36" TV Logo
258 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
