Question about liftmaster Home Security
Where is the "learn button" on an Allister Access 3500 garage door opener?
I am trying to program my new Toyota Truck's garage door opener buttons to work my garage door opener.
  • 3197 Answers
SOURCE: trying to program garage door Access Master will
Try programming your remote this way. Press and hold the button on your remote while you press and immediately release the smart/learn button.
Posted on Sep 15, 2009
SOURCE: how do you program an Overhead Door garage door
Click the button on the overhead unit . it's square it will light up. Click your remote ,it will flash and then it's done
Posted on Dec 30, 2009
  • 3197 Answers
SOURCE: unabler to program a chamberlain garage door opener
If you are absolutely sure you got the correct remotes for your opener then you have a bad logic board.
Posted on Dec 31, 2009
  • 3197 Answers
SOURCE: is there a master reset
There is no reset button. Usually a hole is drilled through the door so the release rope can be pulled.
Posted on Aug 23, 2010
blanchettohd
  • 143 Answers
SOURCE: I have a Merlin Powerlift-Model 2500L Garage door ...
This is a foreign design but here is what the instructions say to do.
Remove the light cover then remove the colored plastic rectangle strip located underneath. This will reveal a red Learn/Delete? button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode. 2. Push the big button on your remote for 2 seconds 3.Push the little button on your remote for 2 seconds Minimum of 1 second is required between each action Your remote will now operate with your motor b) Overhead Doors Remove the coloured plastic rectangular strip located next to the Merlin label on the front of the motor. This will reveal a red Learn/Delete button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode 2. Push the big button on your remote for 2 seconds 3. Push the little button on your remote for 2 seconds *Minimum of 1 second is required between each action Your remote will now operate your unit. Thanks BB
Posted on Sep 03, 2010
Where is the "learn" button on the garage door opener? We are trying to install a new remote opener to this 1145lm opener.
It's on the back of the motor. Press the learn then the remote button. You should hear it click and the light bulb should flash.
Feb 15, 2015 | Building Materials
How do i program my garage ope
Take your old remote and point it at the new remote while pressing 'learn' (or you might only press learn and then shoot the old signal into the new remote). Almost impossible without the old remote though. Hope this works.
Apr 22, 2013 | Building Materials
Remote door opener
So, you get out your remote control to your garage door opener and, then get your owners manual to your new car. You need to follow the instructions from the manufacturer to be able to program the remote control to the car.
Ok, you have followed the instructions from the car manufacturer and you press the button for the garage door to go up.......and nothing happens. So, then you think you have missed a step on the programing. Well, what most instruction manuals leave out is the step from programing the car/truck/van to the garage door machine itself. On the back side of your garage door opener is a panel called the logic board. The logic board is the computer or brain of the machine. Most new garage door openers now are a mulit-code machine. By that, i mean it uses several signals each time you press the button on your remote control. This is for security, so your code can't be stolen by a code-grabber.
Now, comes the step of programing the vehicle to your garage door opener. Once you have followed the instructions of programing your vehicle, you now have to "teach" the car to the garage door opener. You will need some help doing this. You will have to get someone to press the button in your vehicle and hold it down, while someone else has to press the learn button on the back your your garage door opener mounted on the ceiling. The learn button on the back of your machine will be square if using a liftmaster machine. Craftsman, Liftmaster, Chamberlain are all the same. Their learn buttons are square, and usually are yellow, red/orange, or purple. If using a Genie, it has a button that says "learn button".
The person pushing the button on the machine will only have to push and release the learn button. DO NOT hold this button down. If you do, it erases all of the programing in the machine, and you have to re-program all the remote controls that you have. You will have to read my other hub to find out how to do that. You will probably say a few words you shouldn't either. :-) Programing the vehicle to the machine only takes a second, and when the machine accepts the code, the light bulb on the machine should flash for a brief moment, and you should hear audible click. Yep, it's that easy! I dont know why the auto makers leave that step out. Anyway, i hope this helps, and if you have any questions.. leave them in my comments and i will try to walk you through it. See the photo above and you will see the typical logic board...the square red/orange learn button is easy to see. Just remember to press and release
May 08, 2012 | 1995 Lincoln Town Car
Owners manual for allister access 3500 garage door opener
I will send you a link to download a manual. You need adobe reader to download. If you do not have adobe there is a patch there too. Thanks BB
http://www.bearcatco.com/helpgifs2/maindiagrams.html
Sep 14, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a quantum model 3212 serial #3000...fcc id #kj8intrmt...ok im trying to program my garage door to my truck..help please
1. In the vehicle press and hold the two outside buttons until the indicator light begins to flash (after 20 seconds). Release both buttons. Note: Some vehicles may require the ignition switch to be turned to the second (or "accessory") position during the programming process.
2. Hold the end of your handheld transmitter between 1 and 3 inches away from the Homelink surface (located on your visor or overhead console) keeping the indicator light in view.
3. Using both hands, simultaneously push the handheld transmitter button and the desired HomeLink button. DO NOT release the buttons until step 4 has been completed.
4. Hold down both buttons until the indicator light on the HomeLink Wireless Control System flashes, first slowly then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapidly flashing light indicates successful programming of the new frequency signal.)
To train your garage door opener.
1. Locate the smart/learn button on the garage door opener motor head unit.
2. Press and immediately release the smart/learn button.
Firmly press and release the programmed HomeLink button. Press and release the HomeLink button a second time to complete the training process. (Some garage door openers may require you to do this procedure a third time to complete the training.)
Feb 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
PROGRAM PRIUS GARAGE DOOR HOW DO I PROGRAM THE BUTTONS ON THE PRIUS' REAR VIEW MIRROR TO OPEN THE GARAGE DOOR
There was a minor change for mine to work.. see below..
- you must park your Prius close to the gate opener, leaving it running (obviously not in the way of the gate closing)
- Hold the button the the mirror and then push your garage door remote button and hold until the light on the mirror starts to flasyh fast. THIS programs the button on the mirror, but not the garage opener - yet (this was key for me)
- locate the "learning button" on the opener itself
- press the "learning button" on your gate opener and then get back into the Prius within 30 seconds (more time than it sounds) and press the SAME Homelink button you just programmed above. I don't recall how long I held the pre-programmed button, but the light will flash as I recall.
- Then, when working the garage door, you may need to hold the mirror button for a good second for it to work - but I had tried for months to get mine to work, and finally after reading many posts, the above sequence worked on my 2008 Prius with my Lift Master, Security + rolling codes garage opener.
Just - program the button on the mirror with your remote FIRST.. the garage opener will not work.. then use the Learn button on the garage opener and the SAME BUTTON you just programmed.. and it worked great for me. Not programming the mirror button first will not work. Using only the Learn button will not work. You must program the mirror first with the remote, then use the learn button and the SAME button on the mirror. Hope this helps.
Scott 2008 Prius with Lift Master Security + opener.
Oct 30, 2009 | 2007 Toyota Prius
Trying to program garage door Access Master will not program. Followed steps and now car remote will not work.
Sep 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
166 people viewed this question
Top liftmaster Home Security Experts
Lawrence Oravetz
Jean DeLauche
Jean DeLauche
Are you a liftmaster Home Security Expert? Answer questions, earn points and help others
