Question about Welding Tools
Miller 225g blown d4 diode and f1 fuse. No auxilary power or weld
2 Suggested Answers
  • 23 Answers
SOURCE: I have a Miller 225G plus. it idles up good and
Take off shroud, look at where the positive lead hooks into the transformer. You may find that the wire has melted, If you are lucky, you can loop it tnough to make a fresh connection. (also check the negitive)
Posted on Dec 25, 2009
I have a miller welder / Generator 225G plus that does not have any power output
These rigs are notorious for developing bad connections in switches and wiring, as well as getting stuck or burnt brushes in the generator. If it has been sitting for some time, I would definitely do maintenance on the brushes and check switches for rusty or burnt contacts. http://www.millerwelds.com/om/o175104b.pdf
Dec 14, 2014 | Miller Electrical Supplies
Miller 280nt trailblazer has AC power but no weld output? already checked the f1 and f2 fuse
Sounds like an internal problem. You will probably have to take the casing of the welder off and examine all your wire sets. It could be something simple as a connection issue. The transformer may have blown as well.
Jun 03, 2014 | Miller Welding Tools
When I turn on the amp, the lights flicker for a second but it does nothing else. The fuse is good.
Did you check that F1 (red arrows)?. You must open the aluminum cooling in order to find the fuse F1, because it was on the inside, not visible. Usually one of the causes of rupture F1 is one or more diodes (d4/d5/d6/d7) is broken. Check and measure the diode. May also occur, F1 break up just like that, without any other components that causes. This can happen when we open a high level for a long time. It is designed so that the final transistor (which is expensive) not be damaged. Hope it helps. ecae9d89-5530-4ca0-9f14-2f9321ab0aaa.jpg
Mar 16, 2014 | Behringer Bx4500h Ultrabass 450w Bass...
Bobcat 225 runs good but wont weld.Welded great one week prior
Hi:
Probably your machine overloaded. Check the fuses F1 and F2 and if they are open replace them.
Both fuses are located at left hand side of machine, open it and you will find them on the bracket. Check your owner's manual for an ilustration of it.
Aug 05, 2011 | Miller Welding Tools
Miller big 30 d wont weld
Probably your machines overloaded. Check your fuses F1 and F2 and if they are open replace them.
Check your owner's manual for more info about fuse replacement.
Aug 03, 2011 | Miller Welding Tools
Miller 251 NT will stick weld great for about 10 or 15 minutes and then the engine will begin to misfire and won't idle down and then doesn't want to strike an arc. Any suggestions. I had a tech look at it...
This is a very complicated machine and so I will say upfront that only a qualified tech should work on it. There are 2 fuses mounted on a tray holding PCB2. The tray is mounted on the lifting bail. The fuses need to be checked. Also there are circuit breakers and fuses mounted on the front panel that need to be checked. PCB2 is a control board monitoring the output and shuts down the weld power and aux power if there is an overload. The idle board is also watching the output and won't let the machine idle down if there is an overload. I have included the manual. Check Page 27 for overload protection and F1 and F2. An overload will occur if there is a shorted generator, shorted cube rectifiers, or shorted output diodes. Again, after checking F1 and F2, only a qualified tech should work on the machine. Good luc https://www.millerwelds.com/files/owners-manuals/O486H_MIL.pdf
Aug 29, 2017 | Miller Welding Tools
Dec 09, 2009 | Miller MATIC 140 MIG WELDING PKG w/cart...
Miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
May 06, 2009 | Miller Welding Tools
Welding Tools Logo
118 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
