Question about Refrigerators
Ice forming on evaporating tray of refrigerator model 70104001
  • 55 Answers
SOURCE: Whirlpool Refrigerator Model ED25PW Ice maker tray not filling with water
  1. Check to see if water is flowing @ the water inlet valve @ the rear of the unit. You can remove it and clean if out-then put it back in service. You can purchase a new valve -- maybe @ home depot.
Posted on Aug 27, 2008
docjohn174
  • 943 Answers
SOURCE: Ice forming on the a shelf in my refrigerator
Hi .Thanks For The Question. You Probably Have A Drain Problem, From The Freezer TO The Back Of The Fridge. Pull Fridge Away From Wall ,Remove Back Panel Clean All Coils. Locate Drain Hose From Freezer. Clean Tube. And Fridge Is A Bit Too Cold
Posted on Oct 03, 2008
SOURCE: kenmore refrigerator model 106, 2doors, ice forms
I had the same problem and discovered that the water control valve was not shutting off completely between cycles. The water seeping through the valve was freezing in the water inlet tube. I replaced the water control valve for the icemaker and solved the problem.
Posted on Mar 02, 2009
  • 5 Answers
SOURCE: Water/Ice build up in refrigerator
what i would do is...turn your temperature down a little untill you get the resaults you are looking for.
Posted on Mar 20, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Posted on Aug 26, 2009
Water inside refrigerator
Because your model has an evaporator located inside the fresh food compartment it also will have a drain opening below that evaporator. This is a common problem with these dual evaporator models that have drain blockage caused by ice or gunk blocking the drain and causing water to flow below the crisper drawers. Sea Breeze
Nov 19, 2013 | Samsung RS275AC Refrigerator
Ice maker leaks and ice forms in bottom of freezer compartment, water runs out onto floor
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Feb 08, 2011 | LG LRFD25850 French Door Refrigerator
There is a sheet of ice forming in the ice cube tray and a larger one forming on the bottom of the freezer. The GE refrigerator is only 6 months old.
Because the sheet of ice is forming on the ice maker first it leads me to believe the water control valve for the ice maker is leaking water into the ice maker when it should be off. A filter installed before the dual water control valves would also be helpful. If you could find the model number of your refrigerator I would be able to tell you the part number. Sea Breeze
Nov 24, 2009 | GE Refrigerators
My whirlpool gold side by side refrigerator forms a big peice of ice at the very bottom then the ice ends up melting and goes all over the floor whats wrong?
the drain in the back of freezer is blocked
dismantle front of evaporator and deice drain
maybe so hot water over this should fix problem
whendrain is clear water should run donwn hole and collect in evaporator tray under fridge
you may need to mop up after you finish
Nov 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Our 3 yr old LG Model LFC25760SW French door refrigerator over freezer is forming ice on the bottom of the freezer compartment, beneath the drawer. The ice maker switch is off. The water is coming from the...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 25, 2009 | Refrigerators
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
My Maytag side by side (no icemaker) keeps leaking water under the freezer side front roller area. Ice is forming on the inside bottom of the freezer under the bottom basket. I've vacummed underneath and...
OK, You need to unplug for a hour or so. Remove the rear panel in back of freezer to expose the evaporator coils. At the bottom of the evaporator there is a tray that catches the defrost water to take it through the back and down to the condensate tray located near compressor and condenser fan. Most likely you have ice or something trapped in that drain beginning in the freezer. I have heard some people turn the freezer temperatures so cold ice will form before the water can drain. If you still have problem contact me. If this helped vote or rate me. Thanks Sea Breeze
Jun 22, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Freezer section of Kenmore Self Defrost Refrigerator Mfg. 4/07
What you have found as a model number may in fact, be a part number for the inner lining.
Check your owner's manual for the model number.
Check to see if your unit is equipped with a setting for humid/dry climates and if it is present, it should be set to correspond to yours.
The defrost cycle melts concealed, built-up frost, with an internal heating element.
That produces water that should normally drain through a hidden path down to the evaporation tray at floor level under your unit.
If the path is blocked, the water will find its way into the interior and refreeze wherever it lands.
Gaining access to the element and the drainage path can be a real pain in some refrigerators and requires removal of the liner of the freezer for access.
Good luck.
Jun 15, 2008 | Refrigerators
Water always inside refrigerator sometimes ice forms
LadyBlues, This is a top mount freezer. What's happening is that the drain in the freezer area is frozen over. When the unit goes into defrost, the water is running into the refrigerator area instead of going down the drain hole. You will have to remove the freezer bottom panel and then the freezer rear panel to unclog the drain hole. It will be under the evaporator in the drain tray. Use some nice hot water from the microwave and pour it into the tray until the water flows down the drain tube. This should clear up your problem. Catriver.
Jul 12, 2007 | Roper RT14DKX Top Freezer Refrigerator
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
