Question about Toshiba Satellite A135-S4527 Notebook
Desktop won't open
I have a toshiba satellite notebook. i was working in media player, when windo said 'media changing' tried to shutdown, and hit cancel by mistake. now nothing when i try bringing up desktop. it uses vista
  • 128 Answers
Try to start in safe mode by pressing f8 during boot-up, then choose the administrator account and let windows load in safe mode. if you're able to load up to your desktop, restart your pc and log-in as you would normally do.
hope this helps!
Posted on Oct 23, 2008
I just bought a brand new Toshiba Satellite P75-A7200. It won't play DVD's and keeps saying wrong area code...I live in Australia, bought the PC in Australia and am trying to play Australian DVD's but
hi, I think this may help. what you need to do first of all is change the default player for DVD's from Toshiba Video Player to Windows Media Player, cant remember off hand how to do that but should be in manual, but try this. go to windows control panel, select 'Default Programs' and click on it, then select 1st option 'Set Your Default Programs' a list of all programs will come up, look for Windows Media Player and click on it, then choose one of the options on the right. The top one sets as default, the bottom one allows you to set file types to open with the program. this should work as it is telling your system to launch that program for DVD's etc, If you cant find your control panel, simply click Start and type it in the little box that appears just above it.
hope this helps
Nov 08, 2013 | Toshiba Satellite A135-S4527 Notebook
My Toshiba Satellite p15-S470 Laptop lost date and time after shutdown. When i start my laptop it will not proper on and show orange light, after closing and out battery from laptop 2 to 3 time then it is...
try accessing your bios on your laptop and change the date on it. To access the bios just press F2 or F10 once you press the power button. Once you are inside of the bios locate the settings for date and time, then that's the time you can change and save it before you exit.
Hope it helps thanks.
Sep 15, 2011 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Toshiba satellite 5105,only gets a sfar as "toshiba" screen with red lettering.Cant get to bios, hitting esc. worked once and said media failure. What can I do to fix it,or get it to at least do...
First, make sure the ESC key is the proper key to get to the BIOS. You should see a prompt right after you get the Toshiba splash screen to hit a function key to change settings.
I'm thinking because you got a media failure error, your hard drive may be bad and the boot order says to boot to the HD.
Apr 30, 2011 | Toshiba Satellite 5105-S501 Notebook
My Toshiba satellite M45-S331 has a set of buttons to the left of the keyboard that control the disc drive (play, stop, next chapter, etc.). They are currently only working with Windows Media Player. Is...
you may need to download a yahoo widget for your itunes that will allow the buttons to control itunes but chances are they are pre programmed only for media player
Mar 26, 2011 | Toshiba Satellite M45-S331 Notebook
Can Toshiba Satellite L305 be a code free DVD player????
down load a different media player there many good free ones .
Jun 22, 2010 | Toshiba Satellite L305-S5933 Notebook
My advent over heats and shut down when playing media player.
ur advent shutdowns to protect the processor from damage ur advent is nt desktop so u cant apply cpu gel in it.i recommend u to check out the cooling fan working correctly or not ,if it is under warranty then take it to product care center.
Mar 29, 2010 | Toshiba Satellite A25-S207 Notebook
Can't read discs
Is power getting to the drive? Will the tray open and light blink when closing the drive?
If so, it sounds like the lens may be dirty. There are several things you can try: Gently blow into the open drive, use a vacuum, purchase a lens cleaner.
Sep 06, 2009 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellite shuts-down by itself in about 1 minute
Could be hardware or software problems, IF its hardware issue the only problem makes this if the Cpu fan doesnot work, so the Cpu gets hot and then it shutdown in order not to be damaged. but mostly its software issue that remeber if you installed any program before this is happen, and try to stop shutdown by this command, if you did this and this stop shutting down your laptop this is absolutley software problems or programs conflict:
hit Start, then Run , then type this : shutdown -a
this will stop your shutdown if it works, try to uninstall the last programs causes this issue,if it doesnot let you use safe mode command.
Regards
Mar 01, 2009 | Toshiba Satellite M45-S265 Notebook
Unable to play DVDs on my Toshiba Satellite
open windows media player, go to file and look for the open disc and click your cd rom drive. it will automatically read the dvd inside your cd rom
Dec 27, 2008 | Toshiba Satellite A60 Notebook
Keyboard
Hi this Tony my lap top toshiba M45-s265 is making crazy things,when I prees shift key ,everthing changes .the letter go to caps lock size and the numbers changes to works only the symbols, and when this happens also ,if you go to select any folder in my documents on windows you chooice one folder ,with mouse and set all the folders ,what could be happens
Mar 28, 2008 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
