Question about Blaupunkt Seattle MP74 CD Player
What is the use of beep to the blaupunkt mp74
Intermittent bleeping on tuned - in -stations
You have the traffic updates on - I'm not sure the traffic function has ever really worked on the 52 but turn it off and you should lose the annoying beep. As an interesting but annoying aside, you won't find this info on the Blaupunkt FAQ page searching under 'beep' because they describe the noise as a 'peep'... go figure!
http://www.blaupunkt.de/index.php?id=882&no_cache=1&L=1
May 11, 2011 | Blaupunkt Woodstock DAB 52 CD Player
Instructions how to insert unlock code for radio Holden Barina. I have the code just not sure how to input it
If your radio is made by Blaupunkt ( As most Barina radios are ) then here are your instructions.
If yours is a different make then please post a new question quoting the radio MAKE & MODEL
HOW TO ENTER A BLAUPUNKT RADIO CODE
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
Jan 16, 2011 | Blaupunkt Car Audio & Video
There is a beeping noise coming from my Blaupunkt Nashville DAB35, how can i stop this?
Have you recently disconnected the battery or pulled the Blaupunkt out as the beeping is usually due to requiring a code.to be entered into the Blaupunkt
Aug 24, 2010 | Blaupunkt Nashville DAB35 CD Player
Citroen/Blaupunkt radio unlocked but won't stop beeping
VIN coded radio.
Radio will require coding to your car`s management+security system.
Contact your Citroen Dealer or Radio Decoding Business
May 29, 2010 | Car Audio & Video
Operating instructions for blaupunkt 300 in car radio cassette ,got the code but dont know how to punch it in to the radio
ENTER A BLAUPUNKT CAR300 RADIO CODE
Press and hold
Press  Button
Nov 30, 2009 | Blaupunkt Car Audio & Video
How do I enter the radio pin code (which I have) for a 2001 Holden Vectra JS Series? The radio is a BLAUPUNKT factory standard model.
press and hold AS button for a couple of seconds till beep is heard and CODE----
is displayed in the display
use the preset button 1to get 1st number then preset button 2 to get second number etc.... until all 4 digits are entered then press and hold AS button again until beep and radio should start working
Oct 31, 2009 | Blaupunkt Car Audio & Video
Blaupunkt MP74 compatible CD Changers
Specifications
Amplifier
Output power: 4 x 18 watts sine
at 14.4 V and 1%
distortion factor at
4 ohms.
4 x 26 watts sine
in accordance
with DIN 45324
at 14.4 V at 4
ohms.
4 x 50 watts max.
power
Tuner
Wavebands:
FM : 87.5 - 108 MHz
MW : 531 – 1 602 kHz
LW : 153 – 279 kHz
FM frequency response:
20 - 16,000 Hz
CD
Frequency response:
15 - 20,000 Hz
Pre-amp out
4 channels: 4 V / < 1 kω
AUX input
Input sensitivity: 1.2 V / 10 kω
Above are specs for the LA mp74 digiceiver
This is where I found the pdf information for cdc ao71 changer, only problem is it is in other languages.
http://fe0wap79.bosch.de/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/EUR/BeAT_ServiceDocuments-Start;sid=xMwY5KjfON3gIuDbMbhKGKdU-8dWMZg3sZ0=?Language=FR&search_query_name=cdcao71&SellerId=CM_DE
I will keep looking.
Apr 15, 2008 | Car Audio & Video
Blaupunkt MP74 no sound
MGBGT- This is a fairly common problem,you ford has a built in amplifier,there is a wire that needs to be hooked up.If you used an after market adaptor,this wire should be marked and needs to be hooked to the remote turn on lead of the deck.Let me know if you need help. cooltek Mar,4/08
Mar 02, 2008 | Blaupunkt Seattle MP74 CD Player
Demo display keeps running
Here is a link to your owner's manual: http://www.blaupunkt.com/us/download/SeattleMP74.pdf It says: Activating / deactivating demo mode The device is supplied from the factory with demo mode activated. The various functions of the device are displayed graphically as animations in the display during demo mode. You can also deactivate demo mode. ➮ Press and hold down the MENU button for longer than four seconds to activate/deactivate demo mode.
Apr 19, 2007 | Blaupunkt Seattle MP74 CD Player
Blaupunkt Seattle MP74 CD Player Logo
16 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
