Question about Car Audio & Video
Bridge alpine 3553 for sub - Car Audio & Video
3 Suggested Answers
artbesio
  • 55 Answers
SOURCE: want to bridge my alpine 3555 amp to run my sub.
I'm assuming this atleast a 2 channel amplifier all you need to do is hook the negative side of the speaker wire coming from the sub to the negative channel one. and the positive to another positive on channel 2. Should indicate on your amplifier channel one and two. most amps provide a diagram right on the amplifier over top of the speaker inputs. let me know if this helps.
Posted on Mar 08, 2009
  • 19 Answers
SOURCE: i have 4/3/2 ch. alpine f-240 amp- i want to hook
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
Posted on Dec 27, 2009
I have an alpine mrv-f307 4/3/2 channel. I have it hooked up to 2 12in Kenwood subs. Right now standard 2 channel each sub having their own. I heard doing a series hook up and bridging the subs to the amp ...
Bridging an amplifier refers to combining the power of two channels to run one speaker at higher power. If it is wired correctly, your amplifier is running with 4 channels bridged into 2 speakers now.
Mar 11, 2015 | Kenwood Car Audio & Video
How do I bridge this amp to run a single sub?
  • To bridge 1 sub with a Alpine MRV-100M amp you run the negative and positive wires coming from the speaker to the outside terminals on the AMP respectively.
Regards, Tony
May 22, 2011 | Alpine MRV-100M Car Audio Amplifier
What size amp do i need to run 4 1000 watt pyle 10's bridged
well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
I have 4/3/2 ch. alpine f-240 amp- i want to hook up four 6x8 3-way and one 12''sub. the amp has bass EQ on ch. 3. how would i hook it up and get the most power. can i put the 4 6x8 bridged all together...
Dec 25, 2009 | Alpine MRP-F240 Car Audio Amplifier
I would like know whether a sony xplod subwoofer can be connected to my alpine car audio system! xplod sub woofer is 1100 watts.
Deffinitely but wired directly would be pointless, the Alpine's internal amp is way to weak to get the best out of the sub. You need an amp, minimum 300w and bridge the outputs to give all the power to sub preferably switched to low-pass (most amps will have a high / low pass switch)
Dec 07, 2009 | Alpine CDA-7892 CD Player
What is the best way to connect 4 speakers and a sub to a 4 channel amp.
I would connect the 4 speakers to channels 1-2 in stereo with high pass filter. Bridge the sub to channels 3-4.
A thumbs up would be greatly appreciated if this answer is helpful to you. best-way-connect-4-speakers-sub-4-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
May 01, 2009 | Car Audio & Video
Want to bridge my alpine 3555 amp to run my sub.
Mar 07, 2009 | Alpine Car Audio & Video
Mmatsd500.2
First, the specs:
  • PPI 4200am = 50x4 at 4 ohms, 100x4 at 2 ohms
  • Alpine 3553 = 35x4 at 4 ohms, 50x4 at 2 ohms
  • Mmats D500.2 = 350x1 at 4 ohms, 500x1 at 2 ohms
  • 3x Mmats Procast 12 = Dual 4 ohm VC
  • 1x JL 15w6 = Dual 6 ohm VC
  • 2x JL 15w0 = Single 8 ohm VC
Second, I don't think I would recommend mixing n' matching the subs. One of the subs would always be working harder than the rest. If you want to run multiple subs, make them all the same. Sometimes, you can get away with it if they are all the same voice coil impedance, but in this case you've got dual 4 ohm, dual 6 ohm, and single 8 ohm subs all in the mix.
If it were me, I'd probably stay with the single 15w6. But it's your money :)
Mar 12, 2008 | Mmats D500.2 Amplifier Car Audio Amplifier
Wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Jan 22, 2008 | Pioneer GM-X962 Car Audio Amplifier
Car Audio & Video Logo
78 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
