Question about Whirlpool Dishwashers
Removing inner door panel on whirlpool dishwasher model# DU920QWDB3
jsrock516
  • 5911 Answers
SOURCE: Power to dishwasher and will not run
Check your thermal fuse. It will be inside the control panel, clipped to the control board somewhere. It's usually a white plastic square piece with two wires connected to it. The fuse should read a short. If the fuse is blown, you will need to replace it. If the fuse reads good, I would suspect you have a control board problem. Make sure you secure power to the dishwasher BEFORE you take any resistance checks, however. Even if the fuse is blown, you could still have live voltage on one side of the fuse. If you cannot find the fuse, there should be a tech sheet with wiring diagrams inside the lower kick plate below the door. This could be a tremendous help you as well. Let me know what you find.
Posted on Jul 14, 2007
Master_Tech
  • 770 Answers
SOURCE: KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Posted on Feb 22, 2008
  • 171 Answers
SOURCE: Whirlpool DU1100XTPS dishwasher leaking from front door panel
Hi karen_kinzer,
I'm Harvey the Master Plumber.
The d/w was a recent purchase?
Then my advise to you is don't worry about it! The unit should be under warranty. It's time to make the call. Let the warranty repairman worry about it. If he can't fix it, he has the authority to condemn it and you'll get a new one. Anyway, this is one problem you should not have to worry about.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: damaged inner seal tape on whirlpool microwave door window
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 08, 2008
  • 295 Answers
SOURCE: how remove the rear inside door panel on a 2001 oldmobile aurora
The inner door panel is held in by clips and screw.
Look at the door near the door handle there should be screws holding it in and along the outer edge of the door. Once loose, and the door handle removed or the arm rest removed. The door panel then prys out , because of the clips that hold it on. Then pops out by applying pressure to the panel upward to the top of the door. The clips always break because of the design and plastic.
Good luck
Posted on Mar 21, 2009
How to replace front metal panel
Usually (in most Whirlpool models), if you open the door and look, you will see 8 to 10 screws around the perimiter of the door. Remove those, and the outer door panel will come loose from the inner panel. Now just lift the door up a little bit (an inch) to remove it from the 2 catches at the bottom, and you should be able to remove the outer door panel.
May 15, 2015 | Whirlpool DU1055XTS Built-in Dishwasher
The door on my machine won't shut?
Hello
You will need to adjust the dishwasher door latch to fix the door if it will not close. The door latch can come out of alignment from use. Adjusting the latch assembly is a straight forward process on most models of dishwashers. First, remove the securing fasteners for the inner door panel. It is a good idea not to remove the inner door panel completely, just enough that you can access the door latch assembly.
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door.
Pull the dishwasher out of the counter enough that you can access the strike plate securing Torx screw. You may need to open your dishwasher door and remove the two screws that secure the dishwasher mounting bracket to the bottom of the counter with a Phillips-head screwdriver to pull the dishwasher away from the counter.
Loosen the Torx screw that secures the strike plate to the washer tub with a Torx driver. Adjust the strike plate so the plate will engage the door latch. Retighten the Torx screw and push the dishwasher back under the counter. Secure the brackets to the counter if your dishwasher uses retaining brackets.
Adjust Door Latch
Open the dishwasher door and remove the Torx screws securing the inner door panel to the outer door panel with a Torx driver. The retaining screws are usually around the side edge and top edge of the dishwasher door.
Lift the inner door panel enough that you can loosen the two securing bolts on the door latch with a wrench. You only need to loosen the bolts, not remove them.
Carefully raise the dishwasher door to align the door latch with the strike plate. Hold the door latch with your finger tips when you align the latch. Lower the door and tighten the door latch securing bolts.
Install the inner door panel retaining screws and tighten all screws with the Torx driver. Close the dishwasher door and turn on the circuit breaker.
Sep 12, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
Clean light keeps flashing and dishwasher won't start.
If this is a Whirlpool manufactured dishwasher, the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel.
If you still need assistance, please post back with your MODEL NUMBER and let me know
Apr 26, 2011 | Whirlpool Dishwashers
Clean light flashes continually and washer will not start
On Whirlpool manufactured dishwashers, the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
Apr 25, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
8 yr old GU1200 stopped mid cycle - no apparent reason - no response to buttons - appears dead?
These dishwashers have a thermal fuse in the control panel. If it overheats for some reason (sometimes a bad connection on the fuse itself causes that)it will turn whole machine off.
  1. Disconnect power to dishwasher. Remove screws holding the control panel from the side of the inner door. Remove control panel. If it does not come off - remove all screws on the inner side of the door and separate the inner and outer door.
  2. Fuse is on the right side on top of the control board. it usually has tan or black or yellow wires to it. Disconnect wires and check fuse for continuity. if none - replace fuse. Here is your part
Good luck
Vlad
First Choice Appliance
Sep 11, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwasher is a whirlpool model # DU1050XTPB3. The clean button keeps flashing and when I push the start button nothing happens
The blinking clean light is an interruption in the dishwasher program that usually indicates a component malfunction. This can also be a result of a momentary program glitch. If a component is defective, it's usually attributed to the heating cycle or thermostat failure. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Please post back and let me know if you still need assistance.
Jun 24, 2010 | Whirlpool 24 in. DU1050SS Built-in...
Remove the door
The outer door panel makes it easier to get to the bottom. Open the door and remove the screws from the inner liner staring from the bottom on each side working your way up. You will stop just short of the top 2. Have a brace under the panel so it does not fall on your foot. Once the screws are out the panel lifts off.
Apr 25, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool adg 7560
on must hirlpool the top console has control on front upper side,,if so you must remove console and bottom panel,,because your panel will be thicker you must get 1 inch counter screws remove diswasher orginal panel than add you bottom,,,,if it dishwasher that has control bottons on top side of doorplace panel over hold door the remove 4 inner panel screws and replace with 1 and a half in screws ,and mount straight through
Mar 22, 2008 | Whirlpool 24 in. ADG7540 Built-in...
Whirlpool dishwasher - how do i remove timer ??
When I looked up a Whirlpool 2000 dishwasher, it shows an electronic timer. For a mechanical timer, see last paragraph.
First, turn off the breaker for the dishwasher. Then you'll need to remove the Phillips screws around the inside of the door. The inner door panel lifts up, leaving the electronics in place. Disconnect the vent motor and the dispenser motor wires. Place something heavy on the outer panel to keep it down and prop up the inner panel. Remove the plastic cover over the timer - it should pop off. Remove the wires to the circuit board. The electronics are held on with one or two screws.
Mechanical timer: Turn the timer **** backwards. It should come off along with the pointer. This should reveal a 1/4 in ***** holding the timer in place.
Mar 11, 2008 | Dishwashers
Dishwashers Logo
87 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
