Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP OfficeJet 6210 stuck in self test
I have an HP officejet 6210 all-in one injet printer and came home today to scan a documnet plugged it in (not enough outlets, too many surge protectors) and only got a self test and then it won't shut down. Everytime I re-plug it in, it only does a self test and the bar goes to the end and then shuts down. Please advise on what to do next.
  • 1 more comment
  • Midnightstol Nov 08, 2008
    I have the same problem....:(
  • tranmansd Nov 20, 2008
    Same problem. Requested input from HP site and they suggest reset
    the printer by holding down two keys (#6) which still does not work.
    Read some more on the web and see others suggest (# 3) that doesn't
    work either. Anymore advice???
  • Anonymous Feb 10, 2009
    I have the same problem anyone know how to fix it?
  • 4402 Answers
SOURCE: HP Officejet 6210 All In One inkjet printer reset types
Posted on Jan 15, 2008
SOURCE: hp officejet 6210 won't print
Perform the following steps:
a) Turn the printer on.
b) Open the printer’s top cover.
c) After the print cartridges have moved to the center/home position of the printer, unplug the printer’s power cord from the electrical outlet.
d) Remove the print cartridges.
e) Using a dry, lint-free, clean cloth, wipe the print cartridge contacts, from the top to the bottom
f) The contacts inside the printer may also require cleaning. Using a dry, lint-free, clean cloth, gently wipe the contacts, from the top to the bottom
g) Plug the printer's power cord into the electrical outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Now, perform the following:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Apr 01, 2008
SOURCE: install software for HP Officejet 6210
I dont have the installation disk.
Posted on Sep 16, 2008
  • 214 Answers
Here's a link to download the drivers for the 6210. If this helps, plz rate this as 'fixa'. If you have more questions leave a comment & I'll be happy to help. Thank you kindly.
Posted on Feb 22, 2009
  • 372 Answers
SOURCE: how to check ink level on hp officejet 6210 all-in-one printer
  • Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • Posted on Mar 22, 2009
    I have the HP Officejet 6210, it prints but will not scan
    If you are flat bed scanning then try this....Try scanning through the top feeder instead. Mine has had this problem before and it has solved it.
    Dec 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    The Officejet is stuck on SelfTest and stopped working
    Self test is there to test the unit- do a self diagnosis and test the functions of the machine before it is operational, if it gets stuck at one of the test or one of the tests fail then the unit is inoperative until the fault is fixed.
    What you can try is taking the power cord out from the unit while its stuck wait 2 minutes and plug it back in.
    if the issue remains then there are 3 resets that you can try
    partial reset
    semi full reset
    full reset
    here are the partial reset instructions
    the two other resets are, same as the partial reset but the 3 is replaced with a 6 for semi full reset and 9 for a full reset.
    if the problem remains after this then you have a hardware problem, take it to a repairer.
    Nov 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
    Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
    Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Officejet 6210 All in one stuck in self test mode
    Try unplugging the printer for a minute and then plugging it back in.
    Feb 26, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    6210 officejet all in one printer
    check your cartridge try to change thoase cartidge.
    Sep 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    HP Officejet 6210 All in one scanning problem
    Jun 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    Officejet 6210
    there is the problem in the timing gears of your printer
    Sep 10, 2007 | HP OfficeJet 6210 All-In-One InkJet...
    HP OfficeJet 6210 All-In-One InkJet Printer Logo
    398 people viewed this question
    Ben Johnson
