What does error code C-2704 mean on C6500 Bizhub Pro
Error Code C-2704
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
  • 214 Answers
SOURCE: Error code C-D351 on a Bizhub C250
didn't find this code, so dis you read the code correctly and is the model write. you can try troble reset. turn off printer and then on again, holding utility key down. push trouble reset, and reboot again.
Posted on May 11, 2008
SOURCE: Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
Posted on Jun 05, 2008
firecontrol7
  • 6696 Answers
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Posted on Jul 31, 2009
SOURCE: error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Posted on Aug 23, 2009
Error code c0303
Go back to the circuit board you connected the fan to did you remove any other connectors while doing that if so reseat each a very one.
Jul 22, 2014 | Konica Minolta Bizhub Pro C6500 Printer...
Error code C-2704 mean on C6500 Bizhub Pro
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
My best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
Dec 30, 2013 | Konica Minolta Bizhub Pro C6500 Color...
Error code c0101
konica monalta c70hc error code c0101
Sep 01, 2013 | Konica Minolta Bizhub Pro C6500 Color...
Bizhub c 6500 pro code 2840
help me Konica C6500 error code 2840. thanks
May 14, 2013 | Office Equipment & Supplies
Error code 4701 for Konica Minolta bizhub pro C6500
- 4701 error
Communication fifo problem error 4702/4701 of 5500;6500;6501 konica minolta mfp printers
1) reseat all connectors in Ipb
2)image memery controle board
Inspite doing all these if the problem persists please reload the firm ware/flash firm ware.
Last one is to replace image memory board only .no need to replace prcb; overall status board; nvram
Jan 09, 2012 | Office Equipment & Supplies
Konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
Jan 07, 2010 | Konica Minolta Office Equipment & Supplies
What does code 2454 mean on the konica minolta
Jun 08, 2009 | Konica Minolta Office Equipment & Supplies
563 people viewed this question
k24674
jasbo
jasbo
